Turn Signal "Sticks ON" / Found the Cure
My 2005 Excursion had an intermittent problem. Occasionally, the blinker would stay "on" and would not blink.
The shop manual diagnostic chart led me to replace the "multifunction switch" (turn signal stalk) at a cost of over $130. I also inspected the wire cable under the steering column cover and wrapped it in electrical tape where it could possibly chafe. This "fix" did not work.
Finally, I realized that this condition never occurred right after starting the truck. It only occurred after the blinker had been used a few times. In other words, it appeared that something was getting hot.
I purchased and replaced the "flasher relay". This relay was very hard to locate. It is in the dash behind the radio. It is blue, but it resides with another relay inside a black plastic box about the size of a pack of cigarettes.
Problem solved. The new flasher relay has been in for over 8 weeks without a recurrence of the problem.
The part number is 5C3Z-13350-AA. Description is "Relay - Direct". I paid $31.12 plus tax.
Plus it's hard while texting & eating to have a free hand for the turn signal.
I tell folks "modern luxury cars are so expensive, nobody buys the optional turn signals any more".
My wife even points out cars that "didn't buy the optional turn signals".
Sorry, I did not take any pictures. You may be able to get to it by removing the "bag holder hook". I think it is below radio and toward driver side. Use a bright flashlight to look for this black plastic relay holder.
Here is a link to a thread by nomad27 on fuel pump relay that shows a photo of the blue flasher. Hope this helps.
https://www.ford-trucks.com/forums/1...-location.html
im already holding it in my hand.....took out my radio since im putting a new kenwood in.....i have searched and searched to find this thing off and on for about 5 months......never saw that little black cigarette box by looking up from the floor......reps to you......i appreciate it....
granted this is in my F350 not my X they are both super duty platforms so they are the same.......the description of the black box being the size of a pack of cigarettes is right on.....the other way to best describe the location of this black box is right next to the factory harness for the brake controller under the dash towards the passenger side of the harness plug......here are the pics to help you.......
im a bit of a demolition expert so i wanted a good view and took out the whole dash bezel.......
under the "P" is where the cigarette box is.......
here is the box right next to the factory harness for the brake controller.......
this is the black box cover.......
and these are the relays......the blue one is the factory ford and the black one is the replacement from carquest....14 bucks......
hope this helps.....
