Stong smell of unburned diesel from exhaust (not inside the cab)
For awhile now, I noticed a strong smell of unburned diesel coming from the exhaust. I don't smell this inside the cab; only at idle if I step out of the cab.
The smell is such that random folk have commented about it and suggested that I had a sticking injector ... but I have no symptoms of such, fule mileage is on par w/ other 6.0's, & I have no codes. My truck is stock other than a coolant filter.
Anybody else getting a strong scent of unburned diesel at idle??
Engine runs pretty smooth ... only a romp & puff of smoke during a real cold morning start. No contribtion codes ... but I hadn't had a contribution test done in awhile.
I'd get a contribution test run if your getting a strong smell of diesel out the tailpipe. Could have a cracked injector that's leaking excessive amounts of fuel. Left alone long enough might hydrolock,
Not specifically; but, about 10-mos after this post I identified a raw-diesel leak at my fuel pressure regulator. I replaced the housing & gasket (did the blue-spring mod) and the odor diminished mostly.
I can still smell diesel exhaust when running ... I've mostly attributed it to just being the nature of the beast.
90pioneer
6.7L Power Stroke Diesel
15
12-01-2015 09:10 AM
yukonsly
02-05-2006 06:36 PM
