Loose Sway Bar???
Loose Sway Bar???
When accelerating from a stop, I get a clunking sound from the front end. I took some pics of the sway bar and I think it maybe loose. There is a gap between the bolt between the bar. Is this normal, or can I tighten it with the X on the ground or does it have to be up on a lift to properly tighten?
Hi Rob,
Definitely try to tighten it first, that won't cost you anything. Sure looks like a worn out bushing to me though. I seem to remember the bushing sticking out from the metal some and then the bolt staying in contact with the bushing instead. It's been almost five years since I did my end links, so I don't remember exactly.
If you do them, I'd recommend doing the other main bushings that hold the sway bar on too.
If the end links don't solve it, I'd say it's something with the driveshaft. But considering the axle tilts side to side and the sway bar has to also, I think the bushings are gone.
PS, got your pics from your profile...
Mine did the same thing and I git new bushings from energy suspension Energy Suspension Parts Dealer, Specializing in Energy Suspension Bushings Suspension Components. took care of all my bumps and knocks. Common problem it's an easy and not too expensive fix. Good stuff.
To be honest I can't remember how I did it.. But I am pretty dumb haha, I think you can do it with a floor jack and a few beers. Seriously it can't be hard if I did it.
...not sure I follow on the need to lift the truck a bit.
So long as the truck is level left-to-right, there should be no tension on the bar, right? I mean, it works by the angle of the axle in relation to the frame, so if they are both at the same angle, no tension should exist. That bolt can't be under too much tension when level - its designed to allow the axle to move up and down with the suspension.
...or am I temporarily insane?
I ask this because I swapped my sway bar links on my Excursion without any kind of lifting at all, and there was no tension on the bolts other than the expected tension from being fully against the bushings.
If the axle angle differs from the frame angle, the sway bar exerts force to try to 'straighten' itself, counteracting the roll motion of the body.
So long as you are on a flat surface, your truck should sit level left-to-right and not apply any twisting force on those bolts. If you were to tighten those bolts so much that they 'pinched' the sway bar links it would make it harder for the suspension to open and close.
The only way I can see tension being on those bolts would be if the truck was not level left to right or if there was another mount point on the axle, making the sway bar a load bearing component. Sway bars are not meant to carry the load of the truck, only prevent roll.
If I'm wrong guys, chime in.
