'61 ford cabover
The H-series trucks were available in many combinations of engine, transmission and rear axle options. Five Ford big V-8 gas and five Cummins diesel engines supplied the power under the newly designed cab. The V-8 gas engines offered were Super-Duty engines. The H-series trucks were optioned with 401-cu.in. two-barrel and four-barrel, 477 two-barrel and four-barrel, and 534 four-barrel Ford engines. Gas engine models were designated H or HT. Cummins engine options available were 674-cubic-inch NH-180 and NH-195 diesels or 743-cubic-inch NHE-180, NHE-195 or the NH-220. Torque ratings ranged from 504-lbs.ft. at 1,500 rpm for the NH-180 to a whopping 606-lbs.ft. at 1,600 rpm for the NH-220. The NHE or "economy" engines operated at lower rpm, exhaust temperatures and cylinder pressures to improve fuel economy and longevity. Cummins "Pressure-Time" fuel injection was used on the diesels, which was a very simple injection system using a minimum of components. The "PT" fuel-injection system was driven off the engine camshaft. Diesel models were designated HD for single rear axle and HDT for tandem rear axle.
Got it from here: 1961-'65 Ford H-Series cabovers | Hemmings Motor News
1961/65: There are two different Tilt Cabs: C/CT Series & H/HT Series.
Without knowing the year and series of truck, it's impossible to determine what diesel it could have. If you post the VIN, once decoded, all this info will be known.
Wonderful, now look in the 1957/63 Ford Truck Parts Catalog under the Diesel Engine Application Charts and/or the Diesel Engine parts lists.
See if you can find one diesel engine listed for any 1961. Lotsa luck, because the isn't one listed...until 1962.
When the OP posts the trucks VIN, once decoded, the series, engine type/size and the year/month the truck was assembled...will be known.
FoMoCo puts all sorts of jazz in sales brochures, doesn't mean they were available. Sometimes, these features are "teasers" to spark demand among the general public.
I'm 67 years old, been in this hobby since 1956, have owned 337 vehicles, 84 of them FoMoCo products. Purchased 8 new Ford Trucks, 4 new Ford Cars. Was a Ford partsman for 35 years.
When I see FoMoCo proof that they offered a diesel in 1961, then I'll believe it. All three of my 1957/63 Ford truck parts catalogs, printed in 1965, 1968 and 1970 do not list a diesel until 1962.
Quoting from a book about Ford Trucks, written by James Wagner, who is not connected with FoMoCo, doesn't cut it...IMO.
Bill,
First off, much thanks to you for all your contributions to to FTE. You are an honored and esteemed member here and most all of us have benefited from your knowledge and expertise.
To you and everyone else, please, please let's NOT let this forum end up in spitting matches!
Just my humble opinion...
