Timing Chain Replacement - Alignment Marks?
Hi all,
I'm replacing the timing chain on my 1989 E150 302. I'm doing this since the timing cover gaskets are shot and I thought since I'm in there I would just replace the chain and gears too.
I've not taken the old gear set and chain off yet. I'm trying to line up the marks according to my Haynes manual. The crank mark is perfectly at 12 o'clock while the cam mark is slightly off of 6 o'clock. It looks real close but they are not exactly opposite. If you put a straight line on them they do not line up perfectly. How close do these marks have to be? Do they have to line up precisely? Or can they be ever so slightly off and a timing adjustment at the distributor can do the final?
Also, I used a trigger switch connected to the solenoid to bump the motor to align the marks. Is that that suggest way to align the marks? Is there a better way to do this without removing spark plugs?
Thanks for your help.
Rick
Rick
Finger__Rachet
12-17-2012 10:35 AM
Superdave
15
09-30-2002 04:53 PM
