7.3 wont start after injector replacement
Old 01-04-2012, 11:46 AM
jerrytown2001's Avatar
jerrytown2001
jerrytown2001 is offline
i can not get my truck to start after injector replacement. It fired right away then died. now it turns over but nothing happens. any help would be greatly appreciated. 01 f-250 7.3
Old 01-04-2012, 11:50 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Do your batteries have a good charge on them?May need to hook the charger up to them.May have drained the HPOP as well.I bet it will start when you get good oil pressure to the injectors.
Old 01-04-2012, 12:17 PM
jerrytown2001
hpop
i recharged the batteries and it still wont start. how do i get the hpop refilled?
Old 01-04-2012, 12:27 PM
ToMang07's Avatar
ToMang07
ToMang07 is online now
IIRC, don't you have to bleed the air out the GP hole or something like that?
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
There's an allen head plug on the top of the HPOP reservoir. Remove it and fill it up. Takes almost a qt. If it's within an inch from the top, that's close enough.
Old 01-04-2012, 12:29 PM
jerrytown2001
thank you i will try that next
Old 01-04-2012, 12:40 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
You can take the plug off on top and fill it there. How much cranking have you done?
Old 01-04-2012, 01:06 PM
MR5x5's Avatar
MR5x5
MR5x5 is offline
I know when I pulled/replaced my injectors it took enough cranking to make me start thinking I mucked it up. Almost 2 bat charges worth. I did not top of the HPOP....
Old 01-04-2012, 01:45 PM
jerrytown2001
ok so i topped off the hpop. it was pretty low. i cranked but to no avail. i'm recharging the batteries now.
Old 01-04-2012, 01:48 PM
jerrytown2001
ive cranked a lot. i recharged the batteries yesterday. now i'm recharging again
Old 01-04-2012, 02:10 PM
miller_feed
Can you meter the batts while cranking? You need around 10.5 v for the IDM to fire the injectors.
Did you do the fifty cents mod?
Old 01-04-2012, 02:13 PM
jerrytown2001
i will see if i can get someone to help so i can meter them. what is the fifty cent mod?
Old 01-04-2012, 02:38 PM
miller_feed
It's putting a quarter in the UVCH clip, to keep it from disconnecting. But the truck should still start on one bank.
Old 01-05-2012, 08:08 AM
jerrytown2001
ok i've charged the batteries twice since yesterday morning. i cranked on it til i started worrying about the starter. not solid cranking but for 10-20 seconds and then a short break in between. still nothing, not even a sputter. the oil resevoir is just a little under completely full. is there anything else i can do? do i need to bleed the air out of the lines? i havent tried the 50 cent thing yet.
Old 01-05-2012, 08:13 AM
jerrytown2001
i installed a new gasket and harness on my truck along with the injectors
Quick Reply: 7.3 wont start after injector replacement
