2012 Oil Pan Change
Back when this came up before, I felt and stated that Ford's primary concern was cost. The plastic pan was said to be 30-35% cheaper than metal. The plastic pan sells for over $300!! So assuming that Ford keeps consistant margins on parts, that would put a metal pan in the $400ish range!!
It is now said that the new metal pan is $5 cheaper than the plastic pan.
So I figure that all that other hi tech talk about the attributes of the plastic pan was just marketing.
I wouldn't be a bit surprised to hear Ford touting the new metal pan as being superior. Marketing again.
It is likely a silly issue like a supplier problem/cost/raw materiel issue. I would think that with the knowledgeable people that visit this forum, we would know about it if it were a quality or engineering issue.
I would bet the supplier raised the price or ran into problems getting the quantity manufactured according to Ford's demands.
Received 1,449 Likes
on
I don't know why Ford made the oil pan in two pieces in the first place.... This requires making two pieces, a upper and a lower (probably from two different suppliers and requiring casting tooling and injection molding tooling to produce these two items) a gasket, X - amount of bolts and the additional labor to assemble these two pieces.
If Ford was pursuing a cost reduction project you would think that they would just cast the oil pan out of one piece and therefore eliminate the extra materials and labor and could still manage the NVH design requirements.
My opinion for this change was the publics perception of a plastic oil pan with a plastic drain plug wasn't a favorable one.
