1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
airbag light stays on 99 f250 sd
Old 01-01-2012, 11:29 AM
pkm's Avatar
pkm
pkm is offline
Unhappy airbag light stays on 99 f250 sd
i have a 99 f250 sd my airbag light on dash is staying on. the passinger one not lighting up. my heat blower is not working ethier. all fuses good under hood and dash. happened right after 30amp in dash went out
Old 01-01-2012, 11:54 AM
Fulltimer50's Avatar
Fulltimer50
Fulltimer50 is offline
Normally with no other problems it means the passager lite is out. I took the unit out and replaced the bulb with a dash bulb. You seem to have more than one problem.
Old 01-01-2012, 06:48 PM
1973Ford2004's Avatar
1973Ford2004
1973Ford2004 is offline
I second this advice, sounds like a short, start chasing wires on that circuit
Old 01-01-2012, 08:57 PM
pkm's Avatar
pkm
pkm is offline
Air Bag Module, Passenger Air Bag
Activation/Deactivation Switch, Blower
Motor Relay Coil
all on #22 fuse but not blow went out same time
TOB
1997 - 2003 F150
04-19-2011 05:45 PM
ibleedblueoval
1997 - 2003 F150
10-04-2009 12:35 AM
dbthegreat
16
09-13-2006 08:50 PM
Quick Reply: airbag light stays on 99 f250 sd
