BENT RIM ???????
Old 01-01-2012, 01:20 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
I had a set of BF Goodrich tires years ago. They were great, except one went out of round on me. Took it in and they did the same thing. Told me my rim was bent. While on the machine they told me what I was seeing was the rim, but all that was moving was the tire. They refused to replace it. Went to a tire dealer just down the road, had them look at it. They came back and said the tire had failed. To say the least, I don't do business with the other shop anymore, even though the Assistant Manager was a good friend at the time.
Old 01-01-2012, 02:25 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
Good to hear. If too much weight is added, time to try another tire.
Old 09-02-2013, 01:06 PM
Fatstrat's Avatar
Fatstrat
Fatstrat is offline
Having same problem with Wal Mart tires (Goodyear Track-2). Truck pulls to the right. Have had front end checked (and repaired), and an alignment. Still pulls. W-M claims 2 bent rims.
Old 09-02-2013, 01:52 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I Had a problem with Walmart Tires had what's called tread pull
My alignment guy rotated the tires and went away
Old 09-02-2013, 05:23 PM
69cj's Avatar
69cj
69cj is offline
No tire or rim from the mfg. is perfectly balanced. When a new tire is mounted to your rim, if the gods are against you that day, all of the disproportionate weight ends up on the same side. A good tech will see that. I had this happen at America's tire once. I happened to see the tire and wheel when they were putting it on the truck with what looked like a 1/2 lb. of weights on one side. I went and got the manager. He had them rotate the tire on the wheel and rebalance and all was well then. A good balance man knows when things aren't right. Luckily the manager was sharp enough to know what I was talking about. The store I went to is a good store but sh** happens some days.
Softcheeks
1999 to 2016 Super Duty
03-14-2016 03:44 PM
Capt.Schenk
08-16-2014 08:07 PM
Deebo
1997 - 2003 F150
10-23-2007 01:38 PM
romulin
10-11-2004 03:28 PM
Munkey
02-17-2004 07:11 AM
Quick Reply: BENT RIM ???????
