Wheel offset
The wheel offset you want will also depend on the wheel width you pick.
Are you wanting the wheels to stick out past the fenders? If so, how much? No more than they currently do 1" or 2".
What diameter wheel do you want? 18" dia. x 9" wide.
What size tires are you going to use?
Thanks man.
Currently I have 20x10 wheels with a -18 offset (4.79 Backspace). They stick out 2-2.5"
Next set of wheels are going to be 22x9.5 Fuel hostage wheels with a -6 offset (5.00 Backspace) and will stick out about 1.5-2".
A 18x9 with 5" backspace should stick out 1-1.5" give or take a bit.
All this of course is based off my current wheels and how they "appear" to stick out. Depending on where you measure what from. I'm basing my measurements from the center of the wheel opening above the tire.
Mine are 20x10 -25mm, 4.5 backspace. Its a bit of a crapshoot the more negative you go. I have a 2.5" lift 35s as I wanted to stay low enough that a four year old could reach the door handle. I had to trim the fenders slightly behind the tired and space the front bumper out 1.5 in. I like thelook sticking out, others may not. I also get lots of crap on the side windows flipping up.
Stock wheels I believe are 8" wide and your 20s are 10" wide.
Offset is based off the center line of the wheel. The center of the wheel is different on different width wheels.
You could compare the 2 on backspace, then do the math to figure out how much wheel is forward of the hub. Then compare those 2 numbers to tell how much further the new wheels will stick out past the stockers.
on
That would be true with both wheels were the same diameter. Problem is, they're not.
Thanks, if you have time it would be great.
