89 F150 misfire and stumble?
Old 12-25-2011, 07:31 PM
tacotanker27's Avatar
tacotanker27
tacotanker27 is offline
I've been a long time viewer and seldom poster on this forum for a while, but have finally found a problem that I haven't seen covered yet. I have an 89 F150 4.9L that has been misfire and stumbling hard at wide open throttle, and also has a rough idle. The problem is intermitent when cold, sometimes it does it and sometimes it doesn't, but when warmed up it does it 100% of the time. I've put a new o2 sensor, EGR valve, EVP sensor, TPS sensor, FPR, cap, rotor, plugs, and wires into in the last few months and still have this problem. I've checked the exhaust for a clogged cat and it showed no back pressure, cleaned the plenum, checked all vacuum lines for leaks, I tested the EGR vacuum solenoid and it opens when grounded, and right now I've pulled the injectors and have them soaking in cleaner over night.
The truck was driven up until around 2005 when it was parked in a field. The owner needed some work done around the farm and didn't have the money to pay me so I took the truck as a trade in 2009. Im certain the truck hadn't been run in the 4 years it was there because the battery was completely shot when I picked it up, but after replacing it it fired right up.
I've been hunting this problem for a while, it started out as a hardly noticeable misfire that I put off, but has escalated to where the truck is no longer safe to drive. I've taken it to a shop and they diagnosed it as the o2 sensor and possibly the injectors. I don't have much hope in the problem being the injectors as they looked in great condition when I pulled them.
Can anyone help me out with this? I've not a clue what else could be causing these problems.
Old 12-26-2011, 12:04 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
The injectors could be clogged/faulty and not firing properly and thus giving you a miss.
Sounds like you covered pretty much all the other bases.
Old 12-26-2011, 02:35 PM
jk89cat's Avatar
jk89cat
jk89cat is offline
intake gaskets possibly
6Fords
10-04-2014 07:02 PM
hattrick
12-20-2008 10:43 AM
falcon26
13
08-16-2002 11:28 AM
Toms4point9
04-16-2002 08:17 PM
opportunitech
22
08-10-2000 07:21 AM
Quick Reply: 89 F150 misfire and stumble?
