f150 vs gm
f150 vs gm
I have read alot of past posts but wanted to toss this out there again regarding fuel economy of a 2009 or 10 f150 ext cab 5.4 4x4 vs equiv in a gm with active fuel managment. Dont have the cash for newer eco or 5.0l
trucks and not going the lifted route with larger tires as well . Looking for hard honest real world stock fuel economy figures from those who have these trucks. Sorry for bringing it up again. Merry Christmas to all.
I have a 2007 GMC extended cab 4x5 with 5.3L and 4-speed auto. My driving isn't typical as I do a bit more idling than most folks so my mileage figures aren't as good as they 'could' be. Not sure that the 6-speed tranny in the newer models helps as much with city driving, but they're coupled with lower (numerical) gears so they can do better on the highway. Still, cylinder deactivation isn't as great as the advertising makes it sound. Many of us have found that we can get a little better mileage if we leave the transmission in "two-haul" mode as that tends to keep the engine in 4-cyl mode longer.
As noted above, make sure you're comparing similar trucks when buying... especially in terms of gear ratio.
If I were to buy a new truck tomorrow it would be a GMC. I have driven Ford trucks since I was in high school (class of 82). I just want a change and think the current GMCs look and drive better then the current Ford trucks,IMHO. I have had so many hot rods in my past,98% Chevy (built or rebuilt about 35 SBC engines),but have always driven Ford trucks.
I did just the opposite I came out of a GMC, had both a 2000 and then a 2003 5.3 SLT Quadrasteer. Both very dependable, mpg in 16.4 range.
When I decided to buy new the interior of the Ford and the 5.0L won me over. A new GMC just would not have seemed like a new truck with the same basic interior and 5.3 engine.
Only 1700 miles on my 2011 Plat, but no regrets yet.
For what it's worth, our 2010 Supercrew 4X4 with 5.4 and 3.55 axles has averaged 15.7 mpg (hand calculated) over 30K miles with minimal stop-and-go driving...exactly one mpg better than my son gets in his 2006 Supercrew 4X4 with 3.73 axles, bigger off-road tires, and much heavier foot. I hoped to get better, but realistically I'm getting about the same as my other son gets in his 2011 Ecoboost with identical build configuration and axle ratios.
I wouldn't worry about the fuel economy between the two brands it'll be close enough not to be the deciding factor.
Thanks to all that replied. Just trying to gather alittle more info before i switch. Im not 100 percent brand loyal, but ive had great service and luck with every ford we have owned. (dont want to jinx myself) I can deal with mpgs that are close and it appears that they should be, but didnt want to give up 2 plus mpg though. Does the 2009 up 5.4 have a six speed auto trans? That seems like it should help a bit in mixed driveing.
Right, it is extreme to shut down half of the engine in order to make up for the lack of efficiency of an engine. I am leaning towards an 09 or 10 4.6l 6spd. Will only be towing utility trailer periodicly and not putting on oversize tires. Those that have these satisfied with the combination?
