Missouri Chapter Join Chapter , Leader:77&79F250
Need Help with Sons '97 Mustang
Old 12-19-2011, 11:50 AM
spedbugy's Avatar
spedbugy
spedbugy is offline
My sons '97 Mustang Gt keeps blowing the fuse for the computer, I was told this meant the computer was bad, but it still does it with a new computer. Any thoughts what is causing it?
Old 12-19-2011, 11:53 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
What fuse number is blowing?
Old 12-19-2011, 12:08 PM
spedbugy's Avatar
spedbugy
spedbugy is offline
Not sure of the number, it is the ecc fuse. Just found out the battery is bad? Idk if that is what is doing it?
Old 12-19-2011, 12:15 PM
MisterCMK's Avatar
MisterCMK
A bad battery is not going to cause that fuse to pop. You need to get a wiring diagram and start looking for everything that is on that fuse.
Old 12-19-2011, 12:17 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
Do you have a manual for it?
Old 12-19-2011, 12:22 PM
spedbugy's Avatar
spedbugy
spedbugy is offline
No, we don't have a manual for it.
Old 12-19-2011, 12:23 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
I believe that you can go to autozone.com, and access repair manuals through their website. (alldata?)
Old 12-19-2011, 01:17 PM
spedbugy's Avatar
spedbugy
spedbugy is offline
Found the book, it says that the Powertrain control module and the Constant control relay module are the only things on this fuse. I don't have a clue what those are or where they are???
Old 12-19-2011, 01:27 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
The Powertrain control module is the "computer" that you've already replaced.
You SHOULD be able to find the "constant control relay module" in the electrical section of the manual.... (I don't know either. )
Old 12-19-2011, 02:41 PM
cyclopsblown34's Avatar
cyclopsblown34
cyclopsblown34 is offline
Terry, since you're the tech smartypants, will you post a link to this in our jackassery thread? Maybe Alan will see it and have a solution. My first thought was a wire shorting to ground. A wiggle test might be in order once the routing of the wires from the panel to the components is figured out.
Old 12-19-2011, 02:44 PM
thomabb's Avatar
thomabb
thomabb is offline
The owners manual will not list everything on that circuit. You will have to study the wiring diagrams to see what else is powered by that fuse.
Old 12-19-2011, 02:51 PM
earthquake68's Avatar
earthquake68
earthquake68 is offline
Not sure about the '97's but 2000 and up have a small black box under the dash by the steering column. It's full of relays and the dinger for seat belts and such. If one of the relays hangs up or shorts out (pretty common) it can cause all kinds of strange problems. It took me two days to find a parasitic drain on an '02 Mustang. Turns out it was the relay box. It's also considered a body control module. I would try to unplug it and see if it starts.
Old 12-19-2011, 03:25 PM
MisterCMK's Avatar
MisterCMK
It is a 20A fuse labelled EEC?
If so that goes to the CCRM Connector 192 pin 10 and pin 8 and also the PCM Connector 294 pin 55.
At the CCRM pins 8 and 10 look like they are connected to the PCM power relay.
Does the fuse blow as soon as you turn the key to on?
Old 12-19-2011, 03:48 PM
spedbugy's Avatar
spedbugy
spedbugy is offline
Yes, that's the fuse, it blows as soon as the key is turned on. Before we replaced the pcm the fuel pump wouldn't even come on but the motor would crank. Now the fuel pump kicks on until the fuse blows then shuts off again and the motor cranks. I found the ccrm it is inside the fender apron. Pain to get to, will have to wait for the money to get a replacement and go from there.
Old 12-19-2011, 04:08 PM
MisterCMK's Avatar
MisterCMK
Don't shotgun parts at it. Try unplugging the CCRM and see what happens when you turn the key on. You need to determine if it is an issue with a device or with the field wiring.
Quick Reply: Need Help with Sons '97 Mustang
