1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
converting to 4X4?
Old 12-18-2011, 07:44 AM
mark63uni's Avatar
mark63uni
mark63uni is offline
converting to 4X4?
I found a short box close to home here for a decent price, I was wondering if anyone has changed one of these over to 4 wheel drive? And whats the best way to do it, get the drive train and fabricate or put the body on another frame.. any ideas what it might fit on, bronco?
Old 12-18-2011, 11:22 PM
garbz2's Avatar
garbz2
garbz2 is offline
Easiest way is to place a front drive axle on 4x4 leaf springs and lift the rear springs. Add a modern motor and trans/T-case on custom mounts and some drive shafts.
Adding a new fame would not give you any benefits over the frame you all ready have. The frame width is basically the same from 61 to 96. You can use a 44 from a 250 up to 77.5 and convert the hubs over to five lug. A F100 axle 66 and up will be a coil spring type and not conductive to a leaf spring swap.
Garbz
Garbz
Old 12-19-2011, 08:41 AM
mark63uni's Avatar
mark63uni
awesome, thanks
Old 12-20-2011, 01:42 PM
Zip's Avatar
Zip
Zip is offline
My 65 was converted to a 4x4.
mustang_gt_350
03-05-2023 10:22 AM
quesey
11-26-2010 04:02 PM
Fredman
Offroad & 4x4
03-07-2004 10:12 PM
AzPete
12-05-2002 11:39 AM
tony466
12-02-2001 12:18 AM
Quick Reply: converting to 4X4?
