Turbo Removal 06 E350 6.0 HTF Did Ford Come Up With This???
Old 12-16-2011, 07:41 AM
mtnxtreme800's Avatar
mtnxtreme800
mtnxtreme800 is offline
Doing my oil cooler delete, pulled my turbo , what a bitch getting it out, does anyone have any tip getting it back in, it looks like almost impossible to get it up over the drain tube, because its jamming against the cowl, I have'nt taken it apart to clean yet but can it go back in in 2 pcs. I see there is a clamp holding it together i the middle, hopefully someone has done one of these and knows a trick !?!?
Old 12-16-2011, 08:23 AM
dukie1877's Avatar
dukie1877
dukie1877 is offline
your going to want to put that beast back in in one piece. On my 03 there is a small spot it kinda rolls out of just to the left of the oil filter housing there is a video floating around on you tube that kinda makes it look easy. 6.0 Liter Ford Powerstroke - High Pressure Oil Pump & Revised STC Fitting Part 1 - YouTube here is a good one
Old 12-16-2011, 08:29 AM
mtnxtreme800
But you have an F series, so it has no obstructions above with the hood open,
on mine it has the cowl above it, like 2 inches above it, it sucks, actually working from inside the van, it's easier than an F, but when I rolled it like you said to the passenger side, it was good, if it was an F, but then it hits, I had to really drag it accross the cowl, with more force than it should to remove.
Old 12-16-2011, 09:25 AM
dukie1877's Avatar
dukie1877
Sorry I miss read that.
Old 12-16-2011, 09:32 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
Cheezit or Mchan are or maybe your only hope dealing with a van because the majority of us here are trucks. You removed the turbo, just set back or take a walk and think about it, is my best advice when one is frustrated.
Old 12-16-2011, 09:47 AM
69cj's Avatar
69cj
69cj is offline
Not trying to over simplify but if it came out it should go back in. Just need to find the right combination. When I get to a point like this I usually go take a 1/2 hour break and talk it over with mr. bud light. He's a very intelligent person as long as you don't let him take over the project.
Old 12-16-2011, 10:44 AM
dukie1877's Avatar
dukie1877
Lol CJ we have all had him take over a time or two I think.
Old 12-16-2011, 01:38 PM
sammy77's Avatar
sammy77
sammy77 is offline
I worked on one a couple weeks back....what a cluster #%*! All I can say is good luck and those of you who work on em for a living, you are NOT getting paid enough!!
Sorry, I don't have anything else to offer, but I got my *** handed to me on that job.
Old 12-16-2011, 07:16 PM
cheezit's Avatar
cheezit
cheezit is offline
yup theres a trick to it.
trick one....
install turbo without the drain pipe. after turbo is in place roll turbo charger up and slide drain tube in from the front of the engine. still sucks but sucks less
trick 2 remove the left side motor mount and let the pan sit on the k member. this is the easy way to get the turbo in and out... however getting the motor mount out sucks and takes more time.
trick 3
pay someone else.
Old 12-16-2011, 08:21 PM
High Binder's Avatar
High Binder
High Binder is offline
trick one....
Oh man, major face-palm on that one. I put the drain pipe in first and then fought with the turbo for a good 3 hours.
::kicking-self:::
Old 12-17-2011, 07:19 AM
mtnxtreme800
Thanks Cheezit, knew there had to be a better way, and figured someone who did it every day would know. Geez I've seen better turbos that were smaller, you would think ford would use them on the vans and give their mechanics a breakLOL
Old 12-17-2011, 08:37 AM
cheezit's Avatar
cheezit
cheezit is offline
thats why I get paid the big bucks. some times I share, sometimes I dont. however there is no winning with a van.
wiat till you get a bus conversion with duel ac and duel gene's
Old 12-17-2011, 10:11 AM
69cj's Avatar
69cj
69cj is offline
::kicking-self:::
So much for them mechanical degrees!! LOL,
Old 12-17-2011, 10:49 AM
cheezit's Avatar
cheezit
cheezit is offline
and folks that there is funny and I dont care who ya are.
Old 12-17-2011, 11:23 AM
High Binder
It's just a really expensive piece of paper doesn't make you super-human, LOL
IHateCommieCars
10-29-2016 11:26 AM
Dirt Racer96m
04-23-2014 11:30 AM
jesuscowboy
04-14-2014 09:15 AM
67nukeford
03-04-2009 01:39 PM
kensservices
05-23-2006 07:54 AM
Quick Reply: Turbo Removal 06 E350 6.0 HTF Did Ford Come Up With This???
