1983 F150 4.9L 300 Engine hum/whine
Issue: hum/whine in the engine.
I have:
Replaced water pump and harmonic balancer, fixed oil pump bracket in oil pan, checked 1, 2 and 4 main bearings (some unusual wear, but nothing out of spec. limits), checked 1 and 2 rod bearings (again, some wear but nothing out of spec. limits).
Still have the same sound/issue.
Any thoughts on culprit/repair? It's driving me nuts and I want my truck back!
I have:
All the 300 equipped trucks I've had over the years have had a little gear type noise from the front...it's the nature of the beast. How loud are we talking here? Are you able to upload a video...or even just sound?
Me too. My 300 has an almost electric sounding "hum" to it sometimes, that tracks engine speed. I'm not sure a "hum" is a bad thing. Is a "whine" just a higher-pitched "hum"?
I suspect my 300 has the hum/whine from the cam gears. Can't hear it over the whine from the C6.......
I know the 300 has steel gears, as they were listed on that reciept the car lot didn't find. I know they didn't find it, or I couldn't have bought the truck for $300 less than the total spent on the engine rebuild 2 years earlier.......
Did you take off the accessory drive belts and run the engine? Ford power steering pumps are known for being noisy (I hate it when I hear a parts changer say that "they all do that", but most ford PS pumps do make a whine) and that could be the source of your noise, as could the alternator and water pump.
Next time you replace the front crank seal, look at the cam and crank gears. Your 83 should have steel gears (not the fiber ones), and they can be a little noisy. With the timing cover off you can check to see that the timing set isn't rubbing the cover ( a sure sign that the thrust plate is loose), and that the cam thrust bolt is tight; but just check it for tightness-the thrust plate is brittle and easy to break, so don't tighten it more unless it's loose (unlikely).
Good luck.
Good luck.
Any thoughts on it starting up recently?
I'm not able to hear it after it has run for a bit and my heater is on. I believe I'm able to work on it this weekend and I'll see about a video/audio clip. It sounds like extra tension somewhere is making it tough to spin, even with the belts off.
On a 300 L6 Ford it is normal to have a low whirring sound coming from the timing gears. It isn't a precursor to something going wrong. Simply it is an oiling issue, the engine gets enough oil to lubricate the gears but not enough to keep them quiet. If you don't want the whirring you can drive a small roll pin into the oiling hole above the gears. This acts like a straw and extends the oil passage so the oil falls directly on the timing gears. I believe HP Books has a pub on the 300 and the procedure.
Maybe I was lucky...
