Need help with vin on early panel econoline!
I just bought a early panel econoline and the guy said it was a 1962. I am thinking it may be later. I thought it had a 144 motor but now thinking its a 170. Any help with decoding this vin would be great. Here is the vin I found stamped in the back corner.
E14TH496572
THANKS!
E14TH496572
THANKS!
Received 3,106 Likes
on
on
on
January 1964 would be my guess. The VIN looks fine, but I'm not the VIN expert.
There is a little triangular shelf/support between the dashboard and the steering column. The two bolts holding it to the steering column: horizontal in 1961-1963 (heads point towards seat), vertical in 1964 (heads point towards roof).
E14 = Econoline Van.
T = 170 1V I-6.
H = Lorain OH Assembly Plant.
496572 = 1964, assembled January 1964.
90" Wheelbase.
T = Navajo Beige.
E143 = Econoline Van, 3,600 lbs. GVWR
489: 4 = Light Beige Crush Vinyl & Light Beige Stitch Pattern Vinyl / 89 = Econoline Van.
A = Ford model HEF-AH 3 Speed Light Duty Manual Transmission.
01 = Ford WCC-A Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity.
3,600 lbs. Gross Vehicle Weight Rating.
85 net HP @ 3,600 RPM
65 = Oklahoma City OK Ford District Sales Office, where the original selling dealer ordered the Econoline from.
VIN & Warranty Plate decode info taken from the 1964/72 Ford Truck Parts Catalog.
Originally Posted by tjc transport
it seems like the VIN is incomplete. the VIN decoder i use cannot decipher it.
Something is still wrong. There should be a number at the very start of the VIN before the E.
Wrong? Uh...you are referring to a 17 digit VIN, this ain't it.
17 digit VIN introduced in 1981. The first digit is a number, decodes to the country of origin. 1981/96 examples: 1 = USA / 2 = Canada / 3 = Mexico.
on
P10 = P100 model truck
J = gasoline-powered, 223 cui, 6 cyl, 1 barrel carburetor, 114 HP @ 3600 RPM
H = Assembly plant is Lorain, Ohio
424362 = serial number, assembled in June 1963, 1963 model year.
Do you have the rest of the codes on the data plate?
I'm looking at the different forums here at ford-trucks.com, and I think your P100 belongs on the Large Truck discussion board.
Let me know when the ice cream is ready.
Emil
** Note to the next person who needs a VIN decoded - start a new thread.
Emil
