6.7 Glow Plug dropped ( pic added )
Old 12-07-2011, 02:27 PM
BCM's Avatar
BCM
BCM is offline
50,000 miles? Did you get an extended warranty?
Old 12-07-2011, 03:22 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
04xcur - is this on a C&C or regular pickup?
Old 12-07-2011, 03:35 PM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Received 2,566 Likes on 731 Posts
What does an extended warranty have to do with this problem. The engine is covered for 100,000 so he is still covered.
Old 12-07-2011, 03:38 PM
BCM's Avatar
BCM
BCM is offline
I see. Did not realize the warranty went 100,000 miles. Thank you for the clarification.
Old 12-07-2011, 03:39 PM
Hdslider's Avatar
Hdslider
Hdslider is offline
I haven't heard of a pickup doing that, on CC yes. Only heard of a few pickups where bolt came loose and blew injector out.
Old 12-07-2011, 04:49 PM
bpounds's Avatar
bpounds
bpounds is offline
Is there some explanation for that? Are the engines different in the cab/chassis than the pickups? I know the tuning is slightly different, but I'm not sure how that would explain injector or glow plug blowout.
Old 12-07-2011, 05:30 PM
Front Runner's Avatar
Front Runner
Front Runner is offline
He stated he has a regular pickup.
I'm interested in seeing how this turns out. It should be covered under warranty.
Old 12-07-2011, 07:32 PM
EpicCowlick
Thanks, I missed that. This is the first time I've heard of it on a regular pickup. Someone earlier this year had the same issue but it was on a cab & chassis. I'm glad Ford is retrieving the entire engine for analysis.
Old 12-07-2011, 11:15 PM
Monorail_Red's Avatar
Monorail_Red
Monorail_Red is offline
Subscribing, hoping the best for OP.
Old 12-13-2011, 09:27 PM
04xcur's Avatar
04xcur
04xcur is offline
Latest news : Cracked valve !
This week, i stopped at the dealer and to my surprise, the mecanic told me that now they are sure it was a cracked valve... He thinks that it should be covered under warranty ( 99% sure ! )
here is the pictures:
Old 12-14-2011, 12:14 AM
Painted Horse
Did a number on the top of that piston didn't it?
Old 12-14-2011, 12:57 AM
bookem15's Avatar
bookem15
bookem15 is offline
WOW it sure did.... I can not wait to see how this turns out. Good luck I sure hope Ford covers this.
  #28
Old 12-14-2011, 08:04 AM
Hdslider's Avatar
Hdslider
Hdslider is offline
That's just plain sick.hope they get you going as quick as possible.
  #29
Old 12-14-2011, 09:06 AM
EpicCowlick
Those are amazing photos. I'm curious as to what the final repair will be. Clearly they have to replace the piston but what about the cylinder walls, the rod and the crank? Does the entire head have to be replaced? Any mechanics in the audience?
  #30
Old 12-14-2011, 09:27 AM
bpounds's Avatar
bpounds
bpounds is offline
I don't understand how that is a cracked valve. All the valves in that cylinder look intact in the head, and even look properly positioned in their seats, and no damage to the valve bottoms. The witness marks on the piston and head look consistent with the damage that would be done by a small metal object in the cylinder, like a glow plug tip. Maybe I'm missing something?
Quick Reply: 6.7 Glow Plug dropped ( pic added )
