1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Adding a second battery
Old 12-05-2011, 04:20 PM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
I've done some research and decided to go with an isolator and second battery. The second battery is mainly for the plow as it draws so much juice it isn't funny. I am mounting the battery on the frame rail on the passengers side in a plastic battery box. I will run 1 gauge to the isolator & 1 gauge to a ground on the motor.
2 questions - What's the general opinion of doing this? good? bad idea?
Does any one know the exact size of my alternator? I can get a 120 or 160amp isolator and would prefer the smaller size for mounting purposes. I have an 08 5.4.
Thank you for your input.
Old 12-06-2011, 12:08 AM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
I had several bad experiences with insulators on my motorhomes. Not only they drop the voltage, but couple of them had leaks and drained batteries.
Way better is battery combiner, or in your case simple relay activated by ignition should work. Those 200 amp continuous duty relays are hard to buy, but last time I combined several 70 amp relays that sold very cheap on ebay.
Old 12-06-2011, 07:58 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Get an isolator that's rated at least twice the max amperage of your alternator. That way it's not stressed too much, the voltage drop won't be as bad.
Overheating the thing will cause it to short out the rectifier. So mount it somewhere it can get air flow, the engine compartment might NOT be the best thing for it especially when you're plowing.
A starter solenoid makes a good high-amperage switch if you don't go with an isolator.
Old 12-06-2011, 11:07 AM
nitrogen's Avatar
nitrogen
nitrogen is offline
the only time you need an isolator is if you are planning to operate your electrical load extensively while the engine is not running. now unless you have figured out a way to plow snow without the engine running, that really should not be an issue for you. Save the money and aggravation and just hook the second battery up direct
Old 12-06-2011, 01:45 PM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
I would love to do it that way...but I heard my starter is not "wound" for dual batteries and therefore will be short lived. I am trying to find more info on my starter.
Old 12-06-2011, 02:38 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Good luck trying to find anything. You won't. You were given some seriously clueless mis-information. Unless the giver was assuming you were going to wire the two batteries in series? But that doesn't make sense either as the starter frying would be the least of your worries if you dumped 24+ volts into the system.
The starter wouldn't care if you had 1 or 200 batteries. It's going to draw as much current as it needs from whatever source you give it.
Old 12-06-2011, 03:00 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
There is big difference between dual batteries and dual battery banks.
Having dual batteries is common on diesels and with basic know-how it is no big deal.
Dual battery banks are used when second bank is being discharged with engine off and you want preserve starting power in the first bank.
That applies to motorhomes and Police cruisers that use lot of lights with engines off.
I am not familiar with snow plow, but as nitrogen indicate, not likely you really need it.
Old 12-06-2011, 03:04 PM
Sebs's Avatar
Sebs
Sebs is offline
I haven't heard that one before! Just hook them together in parallel - positive to positive and ground the negative. Nothing bad will happen.
Old 12-06-2011, 03:53 PM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
This is what i was thinking about just doing.
Some research I found on the isolator says it would "charge" both batteries equally and seperate accessories (my case plow) from the truck battery?
My whole reason for doing this is to prevent the lights/defroster from dimming everytime I use the plow. I can't believe it is good for the truck to draw so much current over & over & over and having motors and lights dimming.
Old 12-06-2011, 04:07 PM
Sebs's Avatar
Sebs
Sebs is offline
As Nitrogen said, isolators are typically used for running things from a second battery when the engine is off. You can run that battery down and still start your engine with the other battery. When the engine is running both batteries are connected together and the plow would be pulling current from both anyway. So I see no need for an isolator or relay. The lights are dimming because the plow is pulling a huge current load from the battery. With two batteries in parallel, you have twice the capacity to pull current from so the battery voltage shouldn't dip as much and you'll see less light dimming. It may not go completely away but should be improved. Make sure the plow is connected as close to the battery post as possible - preferably at the post.
Old 12-06-2011, 08:37 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
yup sebs and mw are dead on. pos to pos =2x the amperage available, same volts. even perfect connections have a voltage drop, so the more connections between the battery and the alternator the lower your voltage at the battery. wiring in an isolator just adds another level of connections. they will charge better and more equally without an isolator in my opinion.
Old 12-07-2011, 05:14 AM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
OK, 2 batteries, no isolator it is then! Thank you all very much for your input.
Old 12-07-2011, 09:02 AM
aaronbrace's Avatar
aaronbrace
aaronbrace is offline
For what it is worth I agree with the above. I am not familiar with 'isolators' used in vehicles but my assumption would be that they are nothing more than a big diode (or bank of diodes). As soon as you throw a diode in you are going to lose .7Volts from the natural forward voltage drop of a diode.
I would also strongly suggest you ensure that both batteries, the existing and the new, are of a similar age. If the existing one is more than 1-2 years old I would replace it at the same time. Otherwise the newer battery will be pulled down to the older one and spend a bunch of its time trying to charge it.
This is a common problems for battery banks on big UPS systems and Solar systems so I thought I would mention it.
---Aaron
Old 12-07-2011, 10:01 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
Even more important on 48-52V systems because most of those banks are made out of 2V single cells and in a big series string instead of multi-cell batteries in parallel... one open or shorted cell messes everything else up.
Old 12-07-2011, 10:15 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
One problem is when you use that plow a lot, you WILL drain both batteries if the alternator isn't big enough to keep up with it.
If you're going to just wire in another battery, get a real voltage gauge and keep an eye on it. You could potentially shut down the truck and not get it started again
Quick Reply: Adding a second battery
