EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
rear end recommendation
Old 12-05-2011, 01:00 PM
nab101eg's Avatar
nab101eg
nab101eg is offline
I am about to buy a new F-150 4X4 with either the 5.0L V-8 or the 3.5L Ecoboost V-6. Just estimating, I would say that I pull a trailer 10% of the time. Towing includes a midsized boat, midsize RV, utility trailer with a couple of 4'wheelers, small bumper hitch horse trailer, etc. What do you recommend I get for rear axle ratio? THANKS
Old 12-05-2011, 04:25 PM
dkf's Avatar
dkf
dkf is offline
Do you ever plan to go to larger diameter tires at some point?
Myself, I prefer steeper gears to put the most power to the ground so I would go with 3.73s which are the steepest gears offered. Especially with the 5.0l. The extra low end power of the ecoboost helps it to pull a shallower 3.31 or 3.55 easier.
Old 12-05-2011, 09:43 PM
Brad30110's Avatar
Brad30110
Brad30110 is offline
I would recommend 3.55LS. I currently have this rear end gear with an Ecoboost. I love this truck and the miles per gallon vs towing ability. I tow a 4k pound bass boat often and the truck pulls wonderful. My tow rating with these gear and tow package is 9800 pounds which is well above what most people pull.
Old 12-06-2011, 06:45 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,219 Likes on 802 Posts
You didn't tell us how much weight you plan to pull at any given time. The Ecoboost is very "diesel" like and as mentioned, gets you a ton of power down low. An ecoboost with 3.55's gets you 9800 lbs of towing. A 5.0L with 3.73's gets you 9800 lbs. But, the difference in MPG's may surprise you.
The ecoboost with 3.73's gets you a full 11,200 lbs of towing capacity with max tow, 157" wheelbase and the 4x4 package. This capability cannot be had with a 5.0L engine even though it was available on the older 5.4's.
Old 12-06-2011, 09:42 AM
dkf's Avatar
dkf
dkf is offline
Doesn't make sense to me either. The 5.0l has more than enough power to tow that amount especially with the 3.73 gears and newer 6 speed auto IMO. My guess is Ford justs wants to sell more EBs than 5.0ls.
Old 12-26-2011, 05:26 AM
KSCRUDE's Avatar
KSCRUDE
KSCRUDE is offline
If you order the FX4 the 4.10 ratio is now a option with either the 3.5 or the 5.0 I beleave. They offer it on the ford build site. That would be the ratio for me with either engine. The only other 4.10 ratio 150 is the raptor with the 6.2.
Old 12-27-2011, 11:03 AM
NASSTY's Avatar
NASSTY
NASSTY is offline
Nope the 2012 FX4 with 4.10 gears is still only an option on the Ecoboost and n/a on the 5.0.
Old 02-21-2012, 02:18 AM
Brandan78's Avatar
Brandan78
Brandan78 is offline
Hey guys. Bumping this up again. If my top speed will only be about 50-60mph. What gear ratio would you recommend?
Old 02-23-2012, 09:16 AM
TOOLOUD1's Avatar
TOOLOUD1
TOOLOUD1 is offline
If you don't pull a trailer very often and wanna get the best fuel economy I would get 3.55's vs 3.73's. I have 3.73s in my EB and I luv the power but the economy would be better with the other gears. Almost every other tank of fuel I am dragging a trailer somewhere so I wanted the extra umph
Old 02-23-2012, 09:18 AM
TOOLOUD1's Avatar
TOOLOUD1
TOOLOUD1 is offline
[QUOTE=TOOLOUD1;11476024]If you don't pull a trailer very often and wanna get the best fuel economy I would get 3.55's vs 3.73's. I have 3.73s in my EB and I luv the power but the economy would be better with the other gears. Almost every other tank of fuel I am dragging a trailer somewhere so Wanted the extra umph while running around.
Old 02-23-2012, 09:19 AM
TOOLOUD1's Avatar
TOOLOUD1
TOOLOUD1 is offline
........Dddddddd
Old 02-23-2012, 06:15 PM
captaineddie's Avatar
captaineddie
captaineddie is offline
If you drive in an area that has a lot of hills, the 3.73 might work out better for you. In flat terrain I would think a 3.55 would be just fine.
Old 02-25-2012, 11:38 AM
Brandan78's Avatar
Brandan78
thanks guys
rickstuntebeck
2009 - 2014 F150
08-05-2014 02:08 PM
IndyCJ
12-13-2013 03:02 PM
alexleblanc
6.2L V8
15
09-07-2013 05:35 AM
Finler
2009 - 2014 F150
01-19-2011 03:20 PM
Quick Reply: rear end recommendation
