Low tire pressure warning
I rotated my tires a few weeks ago and forgot to reset the TPMS so it gave me the low tire warning. Reset it, everything was fine for a little while. Then the low tire pressure warning popped back up. I checked the tire pressure, and it was low, so I pumped all 4 up to 68 and the warning won't go away. Do I have to reset the TPMS again? Or does the system just take a while to detect the new pressure?
Rather than mess with it. I just run the tires up to Max prssure (80psi) and run around the block and chase an errand or two, Then lower them to what ever pressure I want to run at.
If you are setting them close to the trigger point for the TPMS ( I think 62 psi) remember to set the pressure when the tires are the coldest.
