Oil temp. sensor location?
on
Here's a good thread on the subject. https://www.ford-trucks.com/forums/1...-location.html
Is the temp. reading going to be the same if I placed the sensor in the HPOP reservoir vs. the oil filter housing? Maybe I should ask if one location better than the other for any reason?
They will be a little different. It really doesn't matter that much as long as you compare similar temperatures. The factory chose the HPOP reservoir, I use their sensor along with my Aeroforce Scan Gauge to read the temps. I try to keep my oil temp under 200*. The oil temp will be pretty consistent since the coolant is what is used to cool it.
I also take my oil pressure off of the HPOP reservoir. This allows me to see if the HPOP is ever starving for oil. My pressures may be lower than off of the block, but it doesn't matter since I know it could be lower there.
rechinca
05-14-2017 10:24 AM
ChunderDownUnder
26
11-17-2012 02:58 PM
kirkharrod
32
06-26-2012 01:02 AM
