Brake Light Switch
The pressure activated (by your foot) brake lamp switch is notorious for becoming gummed up with dirty brake fluid.
C1AZ-13480-A (replaced 91A-13480) .. Brake Lamp Switch (Motorcraft SW-24) / Available from Ford and a gazillion autoparts stores.
Applications: Myriad 1939/66 FoMoCo vehicles / Same as Studebaker #666858 = 1941/66 Studebaker, 1951/54 Packard, 1955/56 Packard Clipper w/o Torsion Bar suspension, 1957/58 Packabaker.
Here is a lower PSI activation brake switch used by hot rodders and custom car builders.
Brake Light Switch for Inverted Flare - Speedway Motors, America's Oldest Speed Shop
A Johnson Rod is used to provide timing for seam engine valves, Unlike Kaniflin Pins
Garbz
Garbz
Garbz
Garbz
So it is heat seeking then......... Thanks for clearing that up for me. I do have the right one.
