Oil Cooler O-ring kit
I have a complete felpro gasket set so I'd better double check and see if they are in there.....................duh.......I just assumed they would not be in the kit..
Fel-Pro aught to sell them seperately.
I had to clamp the cooler (steel tube) in a vise as tight as I dared and knock the filer header off with a long nylon block and nylon hammer.
The header on the other end came of with just the mallet.
I'm going to VERY GENTLY use the huge hydraulic press at my Dad's machine shop to reassemble it.
I'm going to VERY GENTLY use the huge hydraulic press at his machine shop to reassemble it.
Once its cleaned up and lubed it will push together by hand. and for petes sake dont use any silicone on the gaskets they will shred.
Victor Reinz sells all the gaskets and the o rings for these engines. Someone posted the o ring numbers. Check out their website they have plenty more. http://catalog.mahleclevite.com/lv/search.php
