Last edit by: IB Cristina
See related guides and technical advice from our community experts:
- Why is My Tire Pressure Light On?
Guide to diagnose trouble and recommended solutions
How do I turn my tire pressure light off?
I bought a 2008 CC F350 lariat the other week with the 6.4 diesel. The next day while driving on a snowy road my tire pressure light came on. I checked the tires, 65 rear and 52 front, both sides equal, none were low.
My tire pressure is fine, how can I reset the light? I press the reset button on the dash for the computer in the gauge cluster, but that doesn't work.
They are stock wheels and stock sized tires.
The light wasn't on when I bought the truck... came on about 300 miles later...
On the drivers door frame is a sticker that should say what the tire psi should be. I do not work on any cc trucks so I can not tell you what it is and it is not in the owners manual.
As far as resetting the tpms, there should be a little remote clicker button in the owners manual package (most are beige with a green button). If not, you will need one of those at the minimum or the software. The instructions on how to set it are in the owners manual under tpms system. Its lenghthy to enter the programming mode and finicky at times. That being said, make sure you set the psis back to what the label says before you reset it. I can send you them if u do not have book or you can view it here.
https://www.fleet.ford.com/maintenan...ls/results.asp
Sometimes, you can set it back to the proper air psi and then drive it a few miles and it will reset. Usually, you will have to do the reset procedure in the book and also will have to do it any time the tires are rotated. Sometimes it will not reset due to a faulty sensor. Your truck should have the band style sensors. The newer trucks have valve stem sensors.
The reset tool simply resets the wheel position within the PCM allowing you to move the rear tires to the front and the front to the rear when rotating. It doesn't allow you to reset the TPMS or override the TPMS in anyway.
I fought this for a long time with my '10 after I lifted it and put my Goodyear MT/Rs on (which I run at about 55 psi). I took all four sensors, put them in a pvc tube with a schrader valve and pump them up to 80 psi and the truck is happy. The air does gradually leak out though so I think I'll make myself a copper version soon.
The pressure given on the cert label will be different for all the different combinations of cab, GVWR, and tires shipped. You cannot assume they will be the same for different trucks, even within a model year.
For the OP, 52psi is too low for your Superduty, and driving in snow will reduce the pressures too. Add a few psi of air and the light will be happy again.
