Roll Pan for '49
No its not the original rearend i dont think. 2 pos back put in this 10 bolt, so i had the wheels made with 5 1/2 "" back space, wich is what you see. There is still a few inches of clearence. Id like to bring the wheels in a littel more, maybe bigger wheels, maybe just less backspace, maybe shorter houseing with tubs, I dont know. I guess the first step will be to to inspect the rearend and see what it is, and what shape its in.
Hey Jim,
If you don't mind me bugging you again, what size wheels are you using with those 295's? I currently have 8" (wide) wheels with a 4" back spacing. The problem is, they are an older aluminum style and no matter what I try, I have one that leaks air pretty bad at the bead. I've re-mounted it, bead sealer, etc. with no luck. Do you run a 10" wide wheel? Mid-Fifty offers an version of the stock steelies that are 15 x 10" with a 5" back spacing, but real estate tucked in that rear fender is already getting scarce. Let me know if you have any opinion/knowledge on this and what you're running. If you wouldn't mind, I'd love to see some more pictures of these tires/wheels on your truck!
Thanks!
Jim
Thanks!
Jim
Hey Jim,
Thanks!
Jim
Thanks!
Jim
