6.0 powerstroke no start
Old 11-21-2011, 11:59 AM
motoX45's Avatar
motoX45
motoX45 is offline
working on a 6.0 powerstroke at work(cat dealer) its one of our service trucks. replaced oil cooler, egr cooler and egr valve. truck was hard to start right after repairs. started and idled good. when first taking it for a ride, the engine and turbo spooled up as it should. but it felt like the truck was being held back. back to shop n check a few things. again idled and reved up fine. took it for another ride, truck took off like it should. got up to about 60mph at WOT, let off and the truck shut up. now its a crank/no start. i have about 580psi to the icp at crank. swapped ficm with a running truck with no luck. any ideas?
Old 11-21-2011, 03:28 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Power Stroke Diesel forum.
Old 11-21-2011, 04:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Here's a good checklist for a no-start. You can speed read thought the first part but always worth going over and it gets to the "meat and taters" pretty quick:
https://www.ford-trucks.com/forums/8...condition.html
Old 11-21-2011, 06:28 PM
cheezit's Avatar
cheezit
cheezit is offline
remove the ipr valve check the screen if damaged repalce it.
Old 11-22-2011, 04:43 AM
hott-rodd's Avatar
hott-rodd
hott-rodd is offline
cheezit saved me with this info a couple years ago , when i had the same problem.
Old 11-23-2011, 10:26 AM
motoX45's Avatar
motoX45
motoX45 is offline
oook so i rechecked it myself with my scanner from home and my icp is only at 65psi. sooo where does that lead me?
Old 11-23-2011, 10:44 AM
brickie's Avatar
brickie
brickie is offline
IPR still it sounds like it stuck and isn't holding the oil pressure.
Old 11-28-2011, 09:21 AM
motoX45's Avatar
motoX45
motoX45 is offline
the screen is in the ipr valve? im not gonna bother taking the valve apart company will just buy a new one just want to make sure i replace everything while i have it apart. any other info? thanks!!
Old 11-28-2011, 09:37 AM
brickie's Avatar
brickie
brickie is offline
The screen is on the end of the IPR,if it has holes in it replace the IPR.
motoX45's Avatar
motoX45
motoX45 is offline
ahh nevermind stupid question thanks guys!
Old 11-28-2011, 09:43 AM
motoX45's Avatar
motoX45
motoX45 is offline
recommend replacing anything else while i have it apart? companys paying for parts and id rather not have to take it back apart haha. the screen on the ipr valve was ripped but i thought i remembered seeing something about a snap to connect fitting that it prone to fail in the HPOP?
Old 11-28-2011, 09:55 AM
BLADE35's Avatar
BLADE35
BLADE35 is online now
man 580 ICP is close
X3 on the IPR very common after this work
Old 11-28-2011, 10:24 AM
motoX45's Avatar
motoX45
motoX45 is offline
yeah 580icp is what i was told by our shops "truck mechanic" i rechecked it with my scanner and came up with 65icp...pulled the ipr and the screens got a hole. just wondering if anyone suggests replacing anything else while i have the turbo out. just replaced EGR valve and cooler, oil cooler and all neccesary gaskets and orings. now ordering up a IPR valve.. anything else?
Old 12-05-2011, 02:19 PM
motoX45's Avatar
motoX45
motoX45 is offline
new ipr, hpop and fitting and the truck runs like a dream. thanks for the help!!
softpickle
01-23-2015 07:45 PM
west127
07-04-2013 09:48 PM
Noey_Gonz
01-03-2012 11:45 PM
slammed03
10-13-2011 12:18 PM
jdeeg4276
08-14-2011 08:18 AM
Quick Reply: 6.0 powerstroke no start
