How fast is too fast for 4x4?
This may be a dumb question but here goes, How fast is too fast while driving on dry pavement while in 4x4? Here in New England, during the winter you can go from 6"of snow on the road to just a dusting within a few feet. Most of my 4x4 driving has been with older full time 4x4 Dodge Ramchargers and the road characteristics were completely different than how my 95 f250 handles. With the Ford, when it's in 4x4 and the hubs are locked, turning a corner on pavement sends the steering wheel rocking back and forth. I never ran into this with the Dodges so just looking for some clarification. Thanks.
With a part time 4x4 you don't want to drive on dry pavement if you can avoid it. Turns are what gets you because all 4 tires want to turn at different speeds and bind up.
Now on a loose surface I've gone 70-75 before with no problems. That was pushing it for conditions, but the driveline was fine.
I've also shifted in and out of 4x4 at highway speeds. Just make sure the rear tires aren't spinning when you engage 4x.
Yes, where I live snow is not common, but when we do get it, the side roads are scary bad until you get to the interstate which is usually fine. So I'll take the truck to work 2-3x a winter, using 4x4 to get from my driveway to the freeway where I shift into 2 high. No good reason to leave it in 4x4 unless you absolutely need to (I have part-time of course).
I've read on another thread on here somewhere that it is not recommended to have the hubs locked but T-case in 2H. It was something that I had wondered myself and then somehow stumbled across that thread. Can anyone clarify this?
Because I just came back from a road trip with bad winter roads and getting in and out to lock and un-lock the hubs is a pain in the ***. If indeed it will cause no harm...I'll be happy to never have to do it that way again.
Leave the hubs locked in until you are sure you won't need 4x4 for the immediate future.
Yes, you can leave the hubs in the locked position, and drive in 2WDH all winter season, shifting to 4X from cab as needed...per Ford owners manual...but, increased fuel use, noise, vibration, and wear
