Up Pipe Exhaust leak
I have a leak where the Up Pipe connects to the Y Pipe, on the drivers side.
From what I have been able to find on the net, the best long term solution is the International Bellowed Up Pipe Assembly. This eliminates the original "donut gasket" which is the alleged problem.
Does anyone know of any other aftermarket Up Pipe / Y Pipe assemblies that would eliminate the stock "donut gasket"?
Any assistance would be appreciated.
Thanks
Civilian Tank Operator
Thanks
Welcome to FTE. Yes, David Lott at Diesel Innovations makes a custom up pipe configuration that eliminates the donut gasket. 7.3l Stainless Up-Pipes
It's also possible to get different up pipes when you upgrade to certain turbos.
The cheapest option is to just go with the International up pipes from one of our sponsors, unless you have a brother in law that works for International.
Riffraff Diesel: International Bellowed Up-pipe Kit 99.5-03
Replacement O-rings for Ford Diesel Engines
The last link has a link with instructions of how to change them.
The DI's have very nice fit and finish.
If you are the type that enjoys fabbing your own stuff you could add bellows to your pipes or another set with some vibrant 400055S bellows, although it will not replace the baby's butt joint, it will allow for proper expansion.
Vibrant Exhaust Fabrication - Steel Bellows - Excelerate Performance - Japanese and European Performance Specialists!!
Let me know if you have any questions. We have them in stock both ceramic and standard.
Call Riffraff and order the IH up-pipes. Several of us have done the research and you won't find a better price. Riffraff Diesel: International Bellowed Up-pipe Kit 99.5-03
And welcome to FTE!
