Shift Tube Replacement
email me at ccerniglia@crowleyauto.net and i'll email you the PDF file. Just hit me with a good rep and we are good.
could you email me this as well. jbrown@landscapesunlimitedcny.com
thanks in advance!
thanks in advance!
Email Sent. Dont forget the good rep.
Thanks for the PDF. I converted to JPEG files so I could post online for all to make use of:
http://photobucket.com/shifttubeandbushingRandR
Note that these instructions are for 2003 Excursion and F350.
Note that these instructions are for 2003 Excursion and F350. Not sure if it varies for earlier models.
As I confirmed with you before over email, it covers about all makes of truck and van from 99-07. MAybe even newer. Can we get a Admin to post this in the tech folder please?
Shift Tube Replacement - Parts List Needed
Gonna dig in and fix my floppy shift-er. Just does not sit right and sometimes I have to fidget to get into the right gear.
Bolts are tight and figure that if I take it apart might as well replace all the worn
parts. --- Model 2002 F250 4x4 7.3
Parts
Shift Tube - Ford (F57Z-7212-A)
(2) Shift Tube Upper Bushing - Ford (F3TZ-7L278-A)
Ford Parts Diagram - Steering Column
Should I also replace the lower tube and spring if I have it apart?
Most likely will get Ford OE parts as I have not always had the best experience with non-oe parts for this truck. And price difference online is not that much.
Any other recommendations would be appreciated.
Parts
atpst81x
01-19-2010 07:17 PM
