4x4 vacuum hoses to front hub
11-13-2011, 04:30 PM
on
hi all...
i'm trying to find the right hose that I need to check and or replace ?
2004 250
thx
11-13-2011, 05:14 PM
Here is a
single post to your question. Can you give a little more information?
11-13-2011, 07:18 PM
on
4x4 vacuum hoses...
My 4x4 on the fly won't engage and I was told it could be the vacuum hoses and I was going to check them..
thanks,
11-13-2011, 07:25 PM
I do not have ESOF but past history on the subject it is probably the hub seals leaking. Do you notice the pump running constantly?
11-13-2011, 08:24 PM
on
4x4 vacuum hoses...
hello... No I haven't noticed anything on the pump... but i'm not sure where the pump is...
11-13-2011, 08:27 PM
on
Passenger side under the hood. Behind the battery. The vac pump has three small tubes going to it. The valve next to the pump is what works the 4x4
11-13-2011, 10:58 PM
on
4x4 vacuum hoses...
thanks... I will take a look and listen first thing tomorrow..
Brook
11-15-2011, 09:32 AM
on
good day,
I found the pump and no its not running all the time.
Is there something else I need to be looking for? its there a way to test the pump?
thanks,
Brook
11-15-2011, 06:34 PM
The pump does not run continuously if everything works and no leaks. You would notice your defrost to floor not working if you had no vacuum. I still vote for the front hubs. Have you manually locked the hubs to make sure the transfer case is engaging?
11-15-2011, 07:36 PM
on
Yes, I have been able to manually lock the front hubs.
So what is your recommendation at this point?
Brook
11-15-2011, 07:38 PM
Check the seals on your front hubs or lock them manually if needed.
11-15-2011, 07:43 PM
on
great.. thanks...
Will start looking into it.. or might just manually lock them.. :_)
will see
11-15-2011, 08:01 PM
on
ARe the front hub seals something that the average joe can change?
or is it something that I need to have done?
Thanks,
BRook
Any youtube videos?
11-22-2011, 09:55 AM
on
f2502003v10
1999 to 2016 Super Duty
02-27-2019 07:25 PM
Hoots250D
02-04-2018 09:01 AM
daculpepp
12-28-2013 09:57 PM
ediaa
02-03-2009 09:16 PM
stroke-of-luck00
10-02-2007 09:12 PM
2002 ,
4x4 ,
73l ,
diesal ,
f150 ,
f250 ,
ford ,
front ,
hose ,
hoses ,
hub ,
lines ,
pump ,
truck ,
tubing ,
vacuum
