How many quarts should my rear differential take?
Old 11-12-2011, 11:03 AM
baumst's Avatar
baumst
baumst is offline
I had been eye balling the drops of oil out of my rear diff and that is probably the next project.
My 1960 F100 rear diff. I am pretty sure it is a 9". How many quarts should it take? (seeing as I do not have a shop manual)
I got the bolt loose and dropped a quart in and I am astonished that it is still not full! (though I could be the first person to open it in 20 years)
I going to town to get more and maybe something to suck it all out for a complete change.
Anyone use that Lucas Oil Gear stuff?
Old 11-12-2011, 11:35 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
Baumst, I never used the Lucas product.I'd be inclined to just stay with standard 80/90 wt gear oil,unless I was starting from scratch with a rebuild.At any rate,it won't heal any noises/problems.
Also,can't say how much the diff will take.I buy a gallon with a pump,and pump slowly till it comes out the fill plug,seal it back up and good to go.It's usually cheaper for a gallon,and I can also use it in the tranny.
Old 11-12-2011, 11:43 AM
baumst's Avatar
baumst
baumst is offline
Yeah... that's what I am thinking... pumping it in. The quart I put in was shocking. There is no issue, no noise... no anything. I am just thinking...."Drops on drive way, change gasket project. Better check oil level." Cool stuff...
Niners beat Giants this weekend... They are the real deal.
Old 11-12-2011, 01:52 PM
spurredon's Avatar
spurredon
spurredon is offline
I would sooner think it is the pinion seal unless you can see it is dry.
Let's hope so about those G-men!
Old 11-12-2011, 01:54 PM
spurredon's Avatar
spurredon
By the way, I believe it should hold somewhere between 2 and 2 1/2 quarts.
Old 11-13-2011, 10:55 AM
baumst's Avatar
baumst
baumst is offline
Ended up down 1.5 qts. Nice. Except for ripping the head off the engine... I think I have been everywhere to make this reliable.
TAT2DUP81
09-13-2012 02:22 AM
doublecanister
05-16-2012 12:13 PM
RckyMntnKng
1999 to 2016 Super Duty
22
01-23-2008 08:20 PM
67FordMustang
1997 - 2003 F150
12-27-2007 10:06 PM
maxbm
Modular V10 (6.8l)
05-17-2005 05:43 PM
Quick Reply: How many quarts should my rear differential take?
