2006 6.0 Glow Plug wiring diagram
Good morning. Did a ton of reading on the glow plug system yesterday and did the OHM check last night. The wire colors on the diagrams I saw posted didn't match the wire colors on my truck. I disconnected the 4 pin plug right behing the alternator and got infinity on the red wire leading to the right bank glow plug harness. I have code P0637 and I want to correlate the red wire to the #3 glow plug circuit. Can anyone confirm that I'm on the right cylinder? Thanks for the help. All other pins on that plug read around 2.3 Ohms so i think I'm pretty close.
2006 F-350 6.0 Powerstroke
P0673 should be plug #3, which is second from the front, passenger side.
My schematic shows the wire color from the GPCM to the plug #3 to be Red/Lt Grn.
Is it possible the Red wire you checked had a Lt Grn stripe that you could not see?
Plug #8 is the solid Red wire.
The GPCM also has a Red wire that is from the ignition.
DigitalFubar
10-29-2017 07:47 PM
