Vibration at 57 mph like a washing machine -- Road Force balance needed?
Hello,
-I have a 2007 Expedition EB with 20" wheels that we bought used with 43k miles on it
-It had the original Pirellis on it and would vibrate at both 57 and 78 mph
-Replaced the tires with Hankooks (inexpensive, highly rated tires) and it did the exact same thing
-Tires began to wear unevenly because of it
-Rebalanced several times to be sure
-Made a stink at Belle Tire about bad tires, for a few extra $$ they replaced with Bridgestone Alenzas
-Same problem, vibration like a washing machine at 57 and 78 mph
-Took it to the dealer. They re-balanced and "found nothing wrong up front"
-Ford mechanic told me it's impossible to get a good balance "on these newer cars," and that I needed to take it to a dealer that has a road-force balancer like they do at the factory
Am I being fed a line of BS? Wouldn't you reasonably think you could get a new set of tires, balanced and true that do not make your car vibrate?
X2 on the road force balance. Had a real hard time getting the 20" Pirelli's on my old 06' F150 to balance without vibration the regular way. Tire guy recommended the road force balance and tires were fine after. Also you could try rotating the tires to the back and see if it makes a difference. The balance only has to be off by a tiny bit to really screw things up at high speed.
Matt
Matt
Quick update on this.
Because of all the trouble I've been having, Belle Tire did a road force balance for me n/c. Made no difference. In fact, the balancing tool showed they were already within spec, but they went ahead and balanced them to almost perfect for me anyway.
They did a visual inspect on the axles to see if they were out of balance. They looked fine and the weights were still in place.
Their thoughts were either the torque converter or drive shaft, but diagnosis was going to be a lot of labor and hassle. This coming from Belle's tech lab in Allen Park - not their usual retail shops. I was the only person their and 5 guys were working on my truck. I was talking to the head of the lab and he was really helpful and knew his stuff.
Problem is, I have an extended warranty through Ford. If I can get them to acknowledge the problem, they'll fix. If not, they charge me labor for diagnosis.
Any suggestions on how to proceed with this? Am I taking the right steps?
Check the wheel torque. Most tire shop monkeys over torque the rims of
Make sure the caliper doesn't have any of the retaining clips on the surface the rim sits flush against. Some trucks have small retaining clips on the studs. It causes a small clearance for some...which can cause issues
Rotate tires
Rotate tires
Contact your closest Ford rep. Find the dealer closest to you that has a "Reed Tachometer". With a Reed tach and the accompanied graph, you can quickly find out if the vibration is in the wheels, drivetrain, engine, accessory item(alternator,water pump.p/s pump,etc) or transmission. I had access to one many moons ago and it was very cool.
They have an electronic version out there too....thats probably better....but my service manager was too cheap!
prosteel1
02-28-2005 10:09 AM
