94 F250 I-beam bushings
Old 11-06-2011, 05:32 PM
94 F250 supercab's Avatar
94 F250 supercab
94 F250 supercab is offline
Are there any aftermarket bushings for the Twin I-Beams (2wd)
Mine are shot and dealer says you need to replace whole I-beam which
is no longer available. Any help appreciated
Old 11-06-2011, 05:39 PM
96B4000's Avatar
96B4000
96B4000 is offline
Are you talking about what I think are called axle pivot bushings? Replaced them on my 94 F250 2wd last year, from oreillys.. Moog I think they were...
Old 11-06-2011, 06:51 PM
94 F250 supercab
These are in the center of frame under engine staggered , on end of twin I-beams in this location. Part # ? for Moog ?
Old 11-06-2011, 07:00 PM
96B4000's Avatar
96B4000
96B4000 is offline
K8620 go to oreilly auto.com type in axle pivot bushings, box of 2 - $49
Old 11-06-2011, 07:02 PM
94 F250 supercab
Thanks !!!!!
Old 11-13-2011, 07:37 PM
94 F250 supercab
Do you have to remove the I-beam or can these bushings be replaced by just droping the center part down ? Do the bushings need to be pressed in ? Any help appreciated.
Old 11-13-2011, 07:43 PM
ChristopherN's Avatar
ChristopherN
ChristopherN is offline
Not to go off topic or anything but, how did you know the bushings were worn out, or did the dealer tell you?
Old 11-13-2011, 08:47 PM
96B4000's Avatar
96B4000
96B4000 is offline
I put a jack under the I, beam, removed the bolt and SLOWLY released the jack to lower the I-beam, I did not even take the tires off, pressed out the bushings, think it was a u-joint press, like a big c-clamp, the one side of it was big enough for the bushings to pass through it. Used pb blaster to help loosen the bushings, took an hour or so both sides total.
Old 11-14-2011, 04:57 AM
94 F250 supercab
I like to look underneath what I'm driving , I'm actually shocked at how bad they were egged out. Truck has around 235,000 miles. They are so bad I'm concerned the bolt could snap. I can't believe this was not noticed at last state inspection. I'll try to take a picture and post
Old 11-14-2011, 05:07 AM
94 F250 supercab
So far I have been told the whole I-beam needs to come off, but looking at it myself, the way you describe is how I thought it can be done.
My concern is trying to do this myself on the ground without the truck falling on top of me. The older I get the more chicken I get I guess.
I don't have a u-joint press but will have to look for one.
Thanks for quick response
Old 11-14-2011, 07:06 AM
96B4000's Avatar
96B4000
96B4000 is offline
I think you could do it with a heavy piece of all-thread, some thick washers and a short section of pipe to pull the bushing into, if you can't find a press, can usually rent/borrow one from a parts house
Old 11-15-2011, 05:47 PM
94 F250 supercab
Did you have to change your bolts ?
Local parts stores around here are asking if my bolts are 1/2 or 5/8 , to get the right bushing
My bolts are metric and between the 2 standard sizes.
Old 11-15-2011, 06:30 PM
thechief66's Avatar
thechief66
thechief66 is offline
You need to find a better parts department.
Part#8C2Z-3B177-A
MSRP $14.98 from FoMoCo
Old 11-15-2011, 07:41 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I put Energy Suspension polyurethane bushings in both my trucks. On 2wd's, the poly bushings have to be installed inside the stock steel outer "cup" that goes around the bushing and presses into the I beams. When I did mine on my 2wd, I didn't even press out the cups. Just cut out the old rubber, ran some sandpaper around the cup to get all the left over rubber off of it, install new poly bushings, bolt I beam back in.
Took us less time to do I beam bushings on my truck than it took 2 guys to change a belt on an '06 Dodge with a Cummins in it. LOL
Old 11-15-2011, 07:45 PM
94 F250 supercab
Part#8C2Z-3B177-A
That's true , went to 2 different dealers both said SOL
Quick Reply: 94 F250 I-beam bushings
