stock timing on 400
Old 11-04-2011, 10:33 AM
Andrew7dg's Avatar
Andrew7dg
Andrew7dg is offline
stock timing on 400
I am new to this v8 engine.
It has a performance cam in there of some kind.
I don't think the timing is set right.
There is a mark on the balancer and a tab. Would that be 0* and I would have to add to that?
Should I buy a timing tape and put that on the balancer?
What should be the final timing or close to what it should be with performance cam?
Later switching out and want to put a stock cam or rv cam as it is pretty gutless down low right at cruising speed however maybe having proper timing would fix.that
Old 11-04-2011, 12:12 PM
garypettengill's Avatar
garypettengill
garypettengill is offline
Start with 12 degrees btdc and go from there. Advance it until the engine starts to "ping" under mild acceleration and the back it off a degree or two.
Old 11-04-2011, 04:57 PM
Andrew7dg's Avatar
Andrew7dg
There are two marks. One on the balancer and another tab. When those are lined up does that mean tdc?
Old 11-06-2011, 09:07 AM
Andrew7dg's Avatar
Andrew7dg
I Advanced the timing, don't know how much because there is only one timing marks to line up but it is running a little better.
Old 11-07-2011, 02:07 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
If you can't find the marks or get a timing light don't sweat it.
Just keep turing it up a littel at a time till it pings like gary said then back it off till it doesn't.
Old 11-07-2011, 05:05 PM
crsmiffy's Avatar
crsmiffy
crsmiffy is offline
I got caned just recently on another forum for saying I dont use a timing light, BUT static time them to start with. I even tried advancing the timing while running, just use gloves or something so you dont get a boot off of the HT leads and dont get wrapped up in the fan or belts. Did the old "advance it till it wont rev any higher at idle and that will be sweet trick" for more power but kicked back on the starter like crazy so no good, did go better on propane with no ping but didn't try on petrol (gas). If it starts well when warm and doesnt ping you would be awfully close.
Old 11-30-2011, 06:13 PM
dsm8's Avatar
dsm8
dsm8 is offline
I went through this same issue with my 400.
Like the others said since you have a light and can see reference marks but dont know what they add up to. Advance the mark by one line each time till you get the ping. Then retard it two and you will for the most part be in the running timing wise.
That is what my truck needed and it made a huge difference.
Old 12-01-2011, 08:38 AM
Andrew7dg's Avatar
Andrew7dg
Thats what I did,
Runs better. I come from the world of lap top tuning with standalone engine management systems. Going to a distributor where you "feel" for timing is a little strange concept for me.
I still don't know what to think of this 400m yet...
Old 12-01-2011, 11:49 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Welcome to the first 100 years of automotive technology.
Old 12-01-2011, 12:03 PM
dsm8's Avatar
dsm8
dsm8 is offline
Here is a thread all about a build up on this engine.
351M/400 Performance Build Up
How We Got Over 500hp from Ford's 400M Engine - Hot Rod Magazine
And Tim or Tom Meyers I think that is his name has a machine shop that specializes in this engine and has some good stuff there too.
http://www.tmeyerinc.com/
But yes, this engine can be built up huge and is a good choice for towing in lue of an engine swap.
Old 12-01-2011, 12:10 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
There is a Read First Sticky at the top with all kinds of good info in it, I'm not going to repeat here what is there....
Old 12-01-2011, 10:25 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
I simply made sure I have timing marks up to 35 degrees BTC on my balancer that are clear and easy to see. As I recall, I think I just made sure what was there was clear? Pretty sure it was factory marked in shorter 2 degree segments between the tens to 30 or 34 degrees. I did add a mark half way between the factory marked 0 & 10 and 10 & 20 and 20 & 30 and then that far above the 30 for 15, 25, and 35 degrees. Too cold to go look now. My 400 balancer is also marked.
Pull vacum, speed motor up until centrifugal advance stops advancing, set timing at 34 degrees with lightso that total mechanical advance is that 34 degrees.
By all acounts of what I've read, these engines like 34 degrees total under load. Mine seems happy at 34 anyway, it pinged and burnt some valves a few years back when I tried higher.
Hook vac hose back up, check to see vacum diaphram is working, done.
Vacum hooked up it'll go up into the 40s under light load / coasting at speed for good mileage but when you mash down on the go peddle, vacume dies, timing drops back for load.
My distributor has a advance kit in it which let's mechanical advance come in sooner so the stock low idle timing specs result in what is actually retarded timing since the advance has started then.
nikwave
16
08-01-2011 05:52 PM
fyrrmann
12-03-2006 01:09 AM
400Nut
06-13-2006 07:44 PM
lifted77f250
04-12-2005 05:42 AM
Galaxie427
02-19-2004 07:08 AM
Quick Reply: stock timing on 400
