Complete wiring harness
What he said, but add that it isn't easy. I have one I pulled from an 85 and it reminded me of pulling a vine out of flowers. It was wound around everything.
Hey bryan23ferra,
I second what Gary said about it being a huge pain to pull. I just pulled the wiring harness from my 86 F150 this last weekend, in preparation for replacement with an American Autowire Universal Wiring Harness. All the stuff behind the dash was a major pain. A number of clips, etc, were really difficult to remove in those cramped quarters. I pulled the steering wheel, instrument cluster, radio, dashpad and finally the drivers side AC duct before I could finally get to the last connector to get it loose. So now I just have to figure out what connectors I have to reuse, and which I can replace with new, and this old rats nest will go in the can. Good luck to you.
I do have that harness available for sale, the one out of the 85. It is the main harness and goes from headlight to headlight, but you would need the other small ones that are specific to your application. However, it really does take disassembling the cab to a great extent to get it out/in.
RE: Complete wiring harness
Yeah, no kidding. Now you guys know why I went to the lengths I am going to on my 86. I am converting to EFI so I can run an E4OD easily on the 460. After looking at my son's 86 F-150 with the 5.0L EFI, I really had to do some serious work to make anything fit the 460, particularly an air filter. I decided to go with a later front end off the parts truck and change the dash also. It since evolved into an even later setup, 92 steering column, 95 dash and currently a 93 front harness, to ultimately become a 95 front harness when it goes to MAF SEFI.
I am curious too how that's going to work out for him. If you have to solder and splice in all the original connectors, then it seems it would just as easy to solder and splice in new wire into the old harness and repair it. You would end up with the same thing correct?
Haven't gotten the kit installed yet, as I just got the original pulled. This kit does provide connectors that requires a special crimp tool. I have a friend who has used it, and raved about it.
While you could splice into the old wires, you then have more connectors still with old brittle connectors, and many wires you can't even tell where they go. At least with the American Autowire kit, they wires are labeled every 3 inches. They also provide pretty detailed instructions. You can view them here. http://www.americanautowire.com/PDFL...20IN%200.0.pdf . I went with the PowerPlus 20 kit for the extra circuits.
