solenoid pack
Old 10-30-2011, 08:48 PM
omanalansan's Avatar
omanalansan
omanalansan is offline
solenoid pack
So i'm getting the O/D flashing light. My AE is ready P0741. I have already flushed my tranny fluid and changed my filter, thought that fixed it but the flashing came back last night on the highway.
Next, is to change my Solenoid Pack. But the only place I see it for sale is Ebay for $235, any other companies sell NEW solenoid Packs?
Here is the one for sale on EBAY.
NEW E4OD 4R100 TRANSMISSION SOLENOID PACK BLOCK 1998-Up | eBay
thanks guys
Old 10-31-2011, 09:34 AM
omanalansan
Anyone??? thanks guys
Old 10-31-2011, 04:09 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Why do you wanna change the shift solenoid? What has led you to believe it's bad?
That code you have listed is for a torque converter, but even if it was for the solenoid, that wouldn't necessarily mean the solenoid is bad.
Stewart
Old 10-31-2011, 08:42 PM
omanalansan
Stewart - thanks for responding to my post. I've been doing alot of research and have read that some people have the same issue that i'm having and replaced their solenoid pack in the transmssion. Also read somewhere that ford instructed owners to change the solenoid pack for trucks made in a range of dates.
The flashing o/d light only comes on everyonce and a while and only when i'm on the highway. Again its not all the time.
I gave BTS a call today but he hasn't called me back yet.
Stewart got any idea what i should do? should i just bring it to the stealership?
Old 10-31-2011, 10:14 PM
mueckster's Avatar
mueckster
mueckster is offline
Are you getting any wierd TC operation when the code sets? It could be caused by many other things other than the solenoid pack, i.e. Electrical Inputs/Outputs, Vehicle Harnesses, PCM, Digital (TR) Sensor, BPP Switch, PCM depending on the symptoms.
Old 11-01-2011, 07:30 AM
omanalansan
Nothing, no wierd operation, everything still works smoothly.
Old 11-01-2011, 07:48 AM
mueckster's Avatar
mueckster
I wouldn't throw any parts at it just yet.
Old 11-01-2011, 09:13 AM
omanalansan
Muekster - thanks for the advise, i'll keep researching.
i just pulled the codes this morning with my AE and I am getting a
P0500 VSS - I beleive this can make my O/D flash. I've read that this part is cheap and i can pick it up at napa or advance auto parts. anyone have hte part number?
Old 11-01-2011, 09:23 PM
Stewart_H's Avatar
Stewart_H
I just know that when the shift solenoid in the 4R100 in my Lightning was bad, the trans shop did something with a multi meter hooked directly to the solenoid to determine if the codes tripping the SES light was due to a bad pack.
It was. They replaced the pack.
My point was, don't just go by the codes that activated the SES light.
Stewart
Old 11-01-2011, 11:09 PM
mueckster's Avatar
mueckster
I agree with Stewart. Read the codes, test the components affected, THEN replace if they fail the tests.
Old 11-02-2011, 07:53 AM
omanalansan
thansk guys for the tip and advise.
Anyone know how to test my solenoid pak? I called BTS but he hasn't return my call..
Old 11-02-2011, 08:03 AM
mueckster's Avatar
mueckster
I have to run over to a friend's shop to help him out for a bit. I'll post up an ohm's test for the solenoids when I get back.
Old 11-02-2011, 09:03 AM
omanalansan
thanks mueckster!!!! your the best!
Old 11-02-2011, 04:02 PM
mueckster's Avatar
mueckster
You're welcome. Sorry it took so long. Got tied up there and he took me out to lunch.
Here's the tests. For the TCC, use the PWM ohm reading
Old 11-02-2011, 04:06 PM
omanalansan
Wow, where did you get this info from?
I'll take you out to a steak dinner after this. ha!
Thanks meukster
Quick Reply: solenoid pack
