Programming an Extra Key
Old 10-27-2011, 08:19 PM
ssjrsw's Avatar
ssjrsw
ssjrsw is offline
Just picked up an 11 5.0 F150 and I am trying to program a third spare key. So far no luck, anyone know if the PATS system changed in the 11 F150 vs the 10 F150? I had a key cut without the integrated fob, I was able to get the spare stand alone fob programed no problem but not the key.
I am inserting the two keys that came with the truck, first key to on position three, then remove put in the second key after three seconds the same way and then the third un-programmed key.
Old 10-28-2011, 06:01 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Old 10-28-2011, 11:50 AM
ssjrsw's Avatar
ssjrsw
ssjrsw is offline
Thanks but I have tried this in accordance with the manual. I am looking to find out if anyone knows of any changs to the 2011 F150's PATS system to set it apart from other Fords.
To explain further the 10 F150 came with a PATS key and separate fob. I happen to prefer this type of key. I have a 12 Mustang and this came with a PATS key with the integrated fob. I was able to cut a key without the integrated fob and program into the Mustang.
I have tried the same with the 11 F150, the separate fob is now programmed and works fine but I can not get the key to program even if I follow the manual. I am hoping someone has a little bit more technical information on the pats system and possible changes.
Old 10-28-2011, 01:18 PM
ebexp94's Avatar
ebexp94
ebexp94 is offline
I bought a spare key on eBay for $20 and had it cut for $2 and had no trouble programming it according to the procedure in the manual. I would take it to the dealer if that isn't working.
Old 10-28-2011, 01:58 PM
countryboy69's Avatar
countryboy69
countryboy69 is offline
What kind of spare did you get? The new f-150 use a 128 bit key. It is different than the old ones and it should be able to be programmed by cycling the key in the ignition.
Old 10-28-2011, 02:18 PM
ssjrsw's Avatar
ssjrsw
ssjrsw is offline
I bought two blank keys, both without the fob (keyless buttons attached) They do say just "S" on them and the 12 Mustang and 11 F150 do say "SA". However one of the spare keys works fine in the Mustang but can not get it to program the in the truck.
Thanks, that is good to know may be a small problem on my end. Do you remember if you did anything special when programming it? I tried starting the truck between attempts to clear it out, doors open and closed but nothing. I know it is a long shot but maybe it is something small I am doing wrong.
Old 10-28-2011, 06:04 PM
shorebird's Avatar
shorebird
shorebird is offline
I think that you have a bad key.
Take it to Walmart auto department and have their new transponder detector test your key.
Old 10-30-2011, 10:22 PM
ssjrsw's Avatar
ssjrsw
ssjrsw is offline
Thanks, they did detect the chip. I guess I will need to to try a SA key. Still don't understand why a S key worked in a 10 F150 and 12 Mustang but not this new one.
Old 11-13-2011, 10:55 PM
ssjrsw's Avatar
ssjrsw
ssjrsw is offline
So I bought another SA key and it worked fine. I do not understand why the S key would work in a 2010 F150 and 2012 Mustang but not the 2011 F150. If anyone plans to make a spare for an 11 plus F150 just make sure it is a "SA" key, it does not matter if the key has the keyless entry buttons or not.
Old 11-14-2011, 06:30 PM
ohboy44's Avatar
ohboy44
ohboy44 is offline
The keys aren't reverse compatible. A "SA" key will work in the old PATS system, but a "S" won't work in the new system of a 2011 F150.
Old 11-14-2011, 09:27 PM
ssjrsw's Avatar
ssjrsw
ssjrsw is offline
This is what I was trying to find out, if the 2011 F150 has a different system then the 10. So you do know for sure that the system on the 150 was changed this year? Appreciate the info since I could not understand why a spare S key worked on the Mustang that came with SA keys but not the truck.
Old 11-16-2011, 08:05 PM
ohboy44's Avatar
ohboy44
ohboy44 is offline
Yes it changed for the 2011 F150.
Any other models that the original keys have the "SA" stamped on them have the new Pats system too.
dchamberlain
1997 - 2003 F150
50
04-27-2019 10:59 AM
jcaspersnow
1997 - 2003 F150
03-13-2011 08:26 AM
jjoyce11
2004 - 2008 F150
01-03-2011 12:33 AM
tapout
1997 - 2003 F150
09-14-2006 06:49 AM
Quick Reply: Programming an Extra Key
