Idle up and down
Old 10-21-2011, 10:26 PM
lilman320's Avatar
lilman320
lilman320 is offline
Idle up and down
I have a 99 F-150 4x4 with the 5.4... While idling it will stay around the 800 rpm range for awhile then what sounds like a switch clicks and it goes up to 1100 rpm then repeats thee cycle... It does this cycle constantly, hot or cold, and I'm just curious as to what makes it do this?
Thanks,
Willie
Old 10-21-2011, 11:17 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Do you hear this click with the ac on? if so its the ac clutch engaging and disengaging the pcm will increase rpm to handle load, if it is cycling too much 6-8 times a minute indicates low refrigerant pressure levels, get charged or low pressure switch malfunctioning IMO
Old 10-22-2011, 09:08 AM
lilman320's Avatar
lilman320
That's exactly what it sounds like, but the ac is off...
Old 10-22-2011, 10:35 AM
kbsupercrew
Ac cycling switch? its on top of the dryer, passenger firewall behind engine harness connector brackets
Old 10-24-2011, 12:19 AM
lilman320's Avatar
lilman320
Would that be the AC clutch switch? More Information for MOTORCRAFT YH1462 I haven't had a chance to look for the one you described I'll try and get to that tomorrow... Thanks again!
Old 10-24-2011, 08:29 PM
lilman320's Avatar
lilman320
And also, if I disconnect the switch will I see a difference in the idle at all?
Old 10-24-2011, 09:49 PM
kbsupercrew
IF you disconnect the connector at the pump or the dryer it shouldnt engage, no a/c, i would think, i never tried
GMAESTRI
1997 - 2003 F150
05-22-2010 08:41 AM
terrier
1997 - 2003 F150
08-29-2009 07:43 PM
Bobert
09-01-2008 09:17 PM
96DRW
09-11-2006 11:43 AM
scraprat
04-24-2004 04:26 PM
Quick Reply: Idle up and down
