Ford explorer turn signal lever not working
Purchased new one from Advanced Auto parts. It worked for a few days and is back to doing what the other part was doing. When I engage the lever to turn right it works but when try to signal to the left it doesn't always work. It makes a noise that sounds like it is shorting out and doesn't turn the signal light on. Depending on how I have the steering wheel turned, sometimes I can hold it to allow for the signal to blink. I replaced the lever, that BTW, also operates the brights and the windshield wipers, for the very same malfunction.
I was not able to pass TX state inspection. Now I,m wondering if it isn't something else that may be causing the lever not to engage. can it be a loose wiring harness?
Did you actually replace the lever, or the multi-function switch? The multi-function switch is where the electrical contacts are made when the lever is moved for turn signals, high beam headlights, flash to pass, as well as the hazard lights. The MFS is probably the issue.
Also, what year is your Explorer?
-Rod
-Rod
Not sure if this applies to your '98 Ex. Common issue on the Gen1 Sport Trac's.
The steering column binds the wiring when tilted, causing breaks and shorting. GL
http://www.mysporttrac.com/MySportTr...epair_Gen1.pdf
turkyhntr
03-07-2007 08:34 AM
Bob Hoyle
06-01-2004 09:19 AM
Kundalini
02-13-2004 10:50 AM
