Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
1999 - 2006 Ford F150 Truck Exhaust Manifold for V6 4.2L Driver Side
Old 10-20-2011, 03:04 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement.
This cast iron manifold has been designed to eliminate the faults of the original design. Designed for use with all emissions and non-emissions vehicles.
Specifications
Fits Rear Side of Engine
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Strengthened and redesigned in the vulnerable areas of failure
Replaces OE Part # Xl3Z9431AA
CLICK HERE FOR CURRENT PRICING
Matt@Flowmaster
06-16-2014 05:54 PM
1Aauto
07-05-2010 01:35 PM
Quick Reply: 1999 - 2006 Ford F150 Truck Exhaust Manifold for V6 4.2L Driver Side
