6.2L V8 Discuss the 6.2L V8
Tranny as brake on inclines
Old 10-17-2011, 06:30 AM
nycsteve's Avatar
nycsteve
nycsteve is offline
Probably an obvious question, but if I wanted to use the tranny to slow speed on hilly terrain to save the brakes from overheating,I'de be best in tow/haul? With 4000#s in the bed, its a truck camper, would I be damaging the tranny, or causing premature wear? Maybe better to be in manual mode and pick a low gear?
I dont have experiance as I usually dont drive where hills are a factor but Im planning a trip out west where steep grades will be a factor for long periods of time.
Old 10-17-2011, 09:11 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
To be honest, I'm not a big fan of how the tow/haul works when going downhill. The downshifts seem inconsistent at times. I'd rather lock out the gears or throw it in M to have more control over it.
You'll definitely want to use the transmission on long hills though, otherwise you'll smoke your brakes pretty quick. Just have to take it easy, don't try and win any races.
Old 10-18-2011, 07:54 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
It's called "engine braking", actually, and shouldn't be a problem. As for tow/haul, no clues there, as I don't have that new-fangled sorta thang!
Old 10-19-2011, 09:46 AM
Onus's Avatar
Onus
Onus is offline
I think your trans will automatically engine brake in tow haul from what i've heard.
I wish my e4od would do that it doesn't even stay locked up when you let of the gas it just starts free wheeling. I can manually shift down into any gear when combined with locking out overdrive. Drive becomes third, then second, and first.
Old 10-19-2011, 01:49 PM
Buckholz's Avatar
Buckholz
Buckholz is offline
I live at 7,000' elevation here in Flagstaff. I tow and go up and down the mtn frequently.
With cruise control on, my tranny will auto downshift to hold max speed. In Tow/haul, it is very aggressive with downshifts. I mostly drive in manual mode, but with downhills, I shift to full automatic and let it downshift. Works great. Works even better if I switch on the A/C to additionally add parasitic drag. I see nothing but positives from using this feature.
thomabb
6.2L V8
05-05-2017 06:53 AM
Novicebutlearnin
6.4L Power Stroke Diesel
15
08-05-2012 11:41 PM
spud57
Fifth Wheel & Gooseneck RV Towing
09-15-2010 07:29 PM
milan
11-20-2007 10:01 AM
rver
08-17-2004 03:42 PM
Quick Reply: Tranny as brake on inclines
