Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How to Replace Rear Shocks
Step by step instructions for do-it-yourself repairs
Bilstein 5100 Shock install with VIDEO!!!
#106
Part of the dual set up is definitely bling, but once you go up to a big enough tire, it does make a difference. If you are staying with stock sized tires, there really is no need for it.
The reason to replace the stock stabilizer is the same reason as replacing the stock shocks... the stock stuff sucks.
My $0.02.
My $0.02.
#107
#108
#109
on
I had the same issue with larger tires. I can't say if it happened with the stock Michellins as I only had them on the truck for about 20 miles. Silverbullet's video is a perfect demonstration as it shows the wobble starting and then quickly coming under control. Almost faster than the naked eye can detect. The slow motion tells all. I figure if you can stop the wobble from happening in the first place with a good shock/stabilizer combo, why not? Even if it happens and is controlled quickly, the suspension will eventually pay a price.
Skip to 6:10 in this video for another view of wobble before and after:
Installing Rancho Steering Stabilizer & RS9000XL Shocks Ford Super Duty - YouTube
#110
Stabilizer vs Damper
Not sure what the difference is between that one and this one:
Bilstein Part 24-158848 - Bilstein 5100 Series Steering Damper
Different model year.
Damper and Stabilizer are the same thing.
#111
#112
It's not THE death wobble, but it's excessive in my opinion. I told my dealer about it, they took my truck on a 1 mile test drive, then said it's not happening. I told them I had a video of it in my truck on my tablet, they didn't care to see it. Instead of getting into a p***ing match with them, I resolved it myself. I think another OEM stabilizer would've done the same thing over time (truck has 10k miles on it) as the roads out here in PA are terrible.
#113
I just got my Bilstein 5100's installed with a leveling kit. The ride is definitely better than the stock Rancho's. I have 22,000 miles on my truck and the stock Rancho's all were all functioning - nothing like what Big Sarge experienced at 2,900 miles.
I could have swore that i had some back shocks as my ride was pretty bad.
Definitely a better ride than what i had for sure!!!
Shame On FORD
Peace
#114
I installed the Carli Bilstein steering stabilizer and my death wobble came back. That was the worst $280 spent ever. I think with the exception of the dual setup, the best stablizer out there is the stock OEM one. Once I installed it back on the truck, no more death wobble. And it was for real death wobble, like wont stop till you stop type.
#115
#116
#117
I hope you have better luck with them than I did. They gave me the run around about when it was going to be shipped, ended up cancelling my order.
@ TXFordGuy1, I sprayed the bolt with WD40 and got a BFH (Big friggin hammer) and wacked it a few times, came right out. I am really happy with how it rides now.
Well, finally got my tracking number from Shock Warehouse....so appears to be on the way...but apparently they are just real slow! 3 weeks or so if it get here Monday as scheduled
#118
Good luck with them...
biz
#119
I also dont have the wobble feeling when hitting pot holes and road imperfections. My front end felt like the video 2000silverbullet posted but not anymore.
The combination of the Bilstein shocks and steering stabilizer have put the suspension where it should be.
Well worth the $ spent.
#120
