f150 rear end problems
I own a 2010 ford f150 that make a grumbling sound when i turn. the dealeship has replased the clutches for the limited slip rear end 2 times now and it is happening again. they told me that the ford engineers are working on the problem but they do not have a fix for it yet. So they told me to just drive it with the positive traction engaged until they get a fix for it. not exactly the answer I was looking for. Anyone else having this problem
It sounds like you have a electronic locking rear? Otherwise how could you control a limited slip rear? If that dealer does not come up with a better answer soon I would go to another dealer. They might have a better crew in the shop. I say that as I know of a now out of business Dodge dealer (BFO before Ford ownership) that told me I needed this and that to rid me of a problem I was having, not really thinking they were right I went to another and the problem was solved but it was totally different fix then the first dealer at a quarter of the price. My two cents, Chris
Somewhat of a misnomer for the dealer to say ".... with the positive traction engaged" ... besides the name, a LSD is always engaged up to the point where the torque bias overcomes the internal clutches.
We had a 2010 at work that had a shutter in the rear and in the trans. IIRC the dealer installed new clutch plates in both to solve the problem. They were two distinct problems with two distinct symptoms.
Odd that replacing the clutches did not cure it. Some guys will just add a couple more bottles of ford's "friction modifier" and for the most part the problem will dissappear. Personally, i do not feel that is a proper fix for the problem. but that is just my humble opinion, and i have known some very good mechanics that will swear by it.
Perhaps the clutches just need a good "break in"? Anyone know how to break in a LSD?
guys, check the lemon laws in your state. If the dealer is passing the repair off until ford tells them what to do they are nothing but a parts changer and wil never fix the issue unless it bits them in the butt. If you have the right in your state, you can write a repair demand letter to ford to make them send an engineer to fix it. Just did that with mine and the truck is in the shop now till they finish replacing the belt drive on the motor that the dealer did not seem to know about. However, I got a 'it can't happen because they resealed it twice' for door leaks.
Remember, you can either chase the current dealer or use capitalism and go find one that wants to fix the issue.
My rear end just exploded going down the highway yesterday and ford won't cover because the previous owner built it as a saleen pickup and it has 23" wheels. Now i'm sitting here with a truck broke down and no way to get it going. I told them about all the issues with the rears and they didn't want to hear, basically told me sorry about your luck.
FordFanFrits
1999 to 2016 Super Duty
11-28-2009 05:23 PM
