95 f-150 radio wires that dont match diagrams?
1995 Ford F150 Factory Stereo Wire Color Diagram?
I'm trying to wire up an old Deck I found laying around up to the truck..however the diagrams I've found are as follows and barely any match what I have in my harness......
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
I can't find the green/yellow constance 12v wire? I have the following power wires from the factory harness
Power
2 - Black/Green
1 - Green/Black
1 - Yellow/Black
1 - Blue/Pink
1 - Orange/Black
1 - Black
Anyone come across this before? I also have a blue/white wire, a brown or tannish/yellow and a grey/pink that arent mentioned.
Thanks in advance!
Power
2 - Black/Green
1 - Green/Black
1 - Yellow/Black
1 - Blue/Pink
1 - Orange/Black
1 - Black
Thanks in advance!
The truck didnt have the factory harness in it when i bought it so im trying to splice the new radio in. Its just strange to me that only about half of the wires match the standard wire diagram....And i really dont want to run it to the fusebox or the battery. I have thought about pulling all the panels and checking the wires to all four speakers but dont want to if i dont have to.
Where are you getting the color code from? A Haynes or chiltons?
You best resort at this point might be a printed factory EVTM specific to your year and model.
I can't find anything reasonable for your '95 F150 but will check with two other sellers I've bought from in the past---they might have one or more hiding in their back rooms.
Will update as I know more.
HTH
HTH
enphluence
67
03-02-2021 05:40 AM
