2011 F-250 .. dash auxiliary switches..
I don't think you can get a matching momentary switch, but you can modify the switch to be momentary. See this thread:
https://www.ford-trucks.com/forums/4...info-here.html
Installing switch bank
Has anyone added auxiliary switches to a truck that didn't come with them? Is there a kit one can buy from the dealer?
I just picked up a '11 F250 and it didn't have them and that was one of my "must ave" options and I would love to install them and have it be as original as possible.
Sure you can. Any dealer can sell you the parts, but the easiest is to buy from a source that knows what is needed.
www.partsguyed.com
www.partsguyed.com
Upfitter switch installation instructions and part numbers can be found in the PDF document at the following link...
http://www.fleet.ford.com/truckbbas/non-html/Q157R1.pdf
NOTE: P/N: BC3Z-14A303-A (Wire Harness) has been superseded by P/N: BC3Z-14A303-B
One of the items I wanted to add to the switches once installed is to have one of the switched set so I can flash my tail lights while towing. Is there a bulletin for that procedure, or has another member done this?
Thanks again,
