1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Petronix for a 62 F100 223 6 Cyl
Old 09-26-2011, 03:27 PM
BeerKnurd's Avatar
BeerKnurd
BeerKnurd is offline
Has anyone else gone the Electronic Ignition route? If so, could you tell me what Petronix part number you went with? Do our trucks run 12 volts or lower? How can you tell for sure? Thank you!
Old 02-08-2015, 04:55 PM
Koolkat's Avatar
Koolkat
Koolkat is offline
Pentronix
I have a '62 292/auto. I have a Pentronix in it and I would do it again. I don't know what part number you would need for yours but make sure that they are lined up properly both air gap and height. Mine missed on one cylinder, I couldn't figure it out. I called the hot line and they told me to make sure that the pole piece and the pickup were on the same plane. I shimmed the pole piece with an O-ring and it solved the problem. Good luck. Install the Speedway disc brake conversion also you won't regret it.
knoxbob
04-02-2018 01:56 AM
ronix08
20
12-27-2015 10:15 AM
richiepan
10-02-2009 05:17 AM
virtualm
08-07-2009 06:00 AM
Azu607
09-10-2005 07:32 PM
Quick Reply: Petronix for a 62 F100 223 6 Cyl
