Rough Idle on 7.3 L diesel
09-24-2011, 09:23 PM
on
I was driving home and the SES light came on and the engine started running rough, I have changed the fuel filter, the air filter, the CPS sensor, reconnected vacuum line to the turbo, checked the wiring harnesses to see if the are loose and cleaned the connections. It is more noticebale at higher rpm's, code reader doesn't show any codes. Any suggestions.
09-25-2011, 09:20 AM
on
Check oil level, how old is the oil. A regular code reader at an auto parts store won't read all the codes on our trucks.
09-25-2011, 09:47 AM
on
Possibly the under valve cover harness, UVCH, is loose.
09-25-2011, 10:19 AM
Quote:
Originally Posted by
scottnchrissy
I agree. Check the ICP too. (Unplug it then start, if problem goes away, ICP needs to be replaced.)
09-27-2011, 07:28 PM
on
Thanks found that oil level has dropped and is in need of oil change, have taken wire connections loose cleaned and put back together.
09-27-2011, 07:38 PM
on
ICP? not real familiar with all terminology, my first 7.3L only had this truck 2 months
09-27-2011, 07:48 PM
on
09-27-2011, 07:53 PM
on
Sensor locations
09-27-2011, 08:19 PM
10-08-2011, 08:16 PM
on
Thanks for all the info, found that he UVCH wiring harness was slightly unplugged problem fixed, runs and starts great now
redbayredneck
12-21-2018 02:46 PM
roger.lees51
46
10-28-2013 09:30 AM
dbrunner94
1999 to 2016 Super Duty
07-26-2013 06:17 PM
Donald Smith
04-02-2011 12:27 PM
Jim Rowley
24
09-18-2008 10:49 PM
73 ,
73l ,
deasl ,
diesel ,
ford ,
idle ,
idles ,
lopey ,
problems ,
rough ,
rpm ,
ruff ,
speed ,
standard ,
varying
