what rear end do i have
Old 09-23-2011, 10:24 PM
79CAMOFORD's Avatar
79CAMOFORD
79CAMOFORD is offline
Here is what I pulled off the rear end housing: S31 3 50 9 5A14
Old 09-23-2011, 10:25 PM
79CAMOFORD's Avatar
79CAMOFORD
S318d sorry on mobile
Old 09-23-2011, 10:33 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
A 31-spline, Ford 9-inch with 3.50 gears.... it's a peg leg - no Traction Lok
Old 09-23-2011, 10:39 PM
79CAMOFORD's Avatar
79CAMOFORD
I take it by calling it a peg leg its not a good rear end?
Old 09-23-2011, 10:54 PM
devino246's Avatar
devino246
devino246 is offline
He just means you'll only have one wheel with traction in a sticky situation since its an open diff.
Old 09-23-2011, 11:01 PM
HIO Silver's Avatar
HIO Silver
A Ford 9-inch is a tough rear end... even the NASCAR Sprint Cup cars (including the Yotas and Chebbies) run a Ford 9.
"Peg leg" is a euphamism meaning it is not equipped with limited slip (Traction-Lok). A burn-out won't tattoo the pavement with two beautiful stripes... just one lame one.
A limited slip or even a locker (PowerTrax or Lock-Rite) can be had for as little as $400 plus labor. The lockers mentioned above can be installed in the driveway and don't require removing the ring gear whereas the Traction-Lok does require disassembly and set-up.
Maybe even a better option is to hunt for the yards for a 31-spline center section with limited slip. If it has the tag, then look for an "L" between the gear ratio. For example, yours would have LS if the tag read 3L50. If you find one, it's a matter of disconnecting the driveshaft, unbolting the axles, pulling 'em out a hair, and then swapping the center section. A $5 tube of RTV and a couple of bottles of gear lube and yer there.
Side note... I think it's kind of ironic we're batting this thread around AND we're the only two FTE'ers in the Dentside forum currently wearing camo schemes. Check my garage and you'll see.
Old 09-23-2011, 11:04 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
the factory limited slips are clutch type. At this point, most are worn out and you don't get reliable performance from them. They are better than nothing, but the open carriers are easier to weld solid, which is what I'm ready to do to mine.
Old 09-24-2011, 06:10 AM
77mud's Avatar
77mud
77mud is offline
spools can be had cheap and work very well
Old 09-24-2011, 09:51 AM
79CAMOFORD's Avatar
79CAMOFORD
Thanks guys ill keep an eye out for the limited slip
Old 09-24-2011, 11:15 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Here is what I pulled off the rear end housing: S318D 3 50 9 5A14
When 8D is typed together, the smilie face appears, unless you 'disable smilies in text' like I just did.
Old 09-24-2011, 01:32 PM
hasteranger
my axle has a smiley face stamped into the housing....
Bootzz711
11-20-2011 11:17 AM
tandolla
04-15-2009 09:45 PM
gsx
07-02-2002 05:30 PM
hernando
02-09-2002 02:30 PM
Quick Reply: what rear end do i have
